Old 11-16-2002, 10:40 PM
jmx
Wink Diff slippage?
I just got my Epoch 1/43 Integra R blue body today. It seems a lot cooler than the defective Z-car (Zip Zap type) that I returned to Hobby People today. The Epoch is waaaay more car IMHO (also a lot more money for a tiny).
My problem is that I seem to be experiencing a lot of diff slip in my Epoch. The car goes downhill well but let it encounter a small uphill (like a slightly off level garage floor) and the car slows noticibly with much more noise that sounds like the diff slipping on a 1/10 scale car.
Is this normal? Can I tune the diff and tighten it up for a little less slip?
jmx
Old 11-17-2002, 12:21 AM
irc irc is offline
It is possible that your wheel is spinning on the hub. If so you can use some very thin doubble sidded tape to fix it.
" THINK FAST "
Old 11-17-2002, 02:32 AM
jmx
Wink The wheel doesnt seem to be slipping
The wheel doesn't seem to be slipping at all.. I've looked at both sides as this car seems to have some sort of limited (if tiny) diff.
If I hold both wheels, the motor does bog, but when runnning it seems to spin up while the car is not accelerating, but moving slowly.
jmx
Old 11-17-2002, 09:18 AM
irc irc is offline
The diff and wheel hubs are a press fit to the axel. If any of these are slipping you should send the car in for warranty as I don't think it is fixable. Epoch needs to have replacement parts available especialy diff's.
" THINK FAST "
Old 11-28-2002, 07:39 AM
Taigerr Taigerr is offline
Can the diff be TOTALLY dismantledand if so how?? I gotta get in to get a tangled hair out.... wish me luck.. SOB!! SOBBBBBB!!!!!
Old 11-28-2002, 04:43 PM
well found out how to dismantle the diff..... and bust it in the process..... HELP ANYONE GOT A SPARE SPEC 2 DIFF FOR SALE??????????
should i lock my front diff bengali548 XMODS Parts and Hop-Ups 2 08-01-2006 07:43 PM
What's a Diff (Differential)?...Here's the answer Namuna XMODS Parts and Hop-Ups 3 07-02-2006 12:44 PM
Ball Diff Behavior vejur79 XMODS 4 11-04-2003 04:51 PM
Diff ... Diff e_lm_70 Epoch RC1/43 2 11-26-2002 04:29 AM
diff handling with diff bodies? kombatgti Bit Char-G / MicroSizers 2 11-07-2002 09:20 PM
