Old 11-14-2002, 05:11 PM
TEAM_NITRO's Avatar
TEAM_NITRO TEAM_NITRO is offline
? 4 Gertman!!!!!
Can a guy use a 150 mah cell as a fourth cell in the Spec 2 120 mah pack??? All batteries would be ni m.
Thank You in advance for any advice!
TEAM NITRO
Old 11-14-2002, 06:37 PM
gertman's Avatar
gertman gertman is offline
I suppose you could BUT battery life would probably be compromised. What I mean is that total number of times you could recharge would decrease and so would run time. BUT, on a counterpoint, because it is of a higher MAH rating I don't think it would be so bad.
I would say it's a more short term solution..............but then again if you charge you pack carefully (don't let it get hot) and 1st regulate the pack it may be fine. What I mean by regulate is charging and discharging the newly modded pack severly times at very low amperage if you don't have access to a charger that will automaticlly do this.
-Engineering Manager
Old 11-14-2002, 07:03 PM
TEAM_NITRO's Avatar
Gertman,
Hace you had messed around with four ni cad's out a Tomy Bit Char-G in a Epoch? If not what are your thoughts???
Thank You
TEAM NITRO
Old 11-14-2002, 07:33 PM
gertman's Avatar
No, for my 4th cell I used a spare one left over from a friends broken car.
Old 11-14-2002, 07:50 PM
TEAM_NITRO's Avatar
What is your opinion on ni cads instead of ni mh??? More power?
Would the Tomy bit batteries work?
Thank You again!
TEAM NITRO
Old 11-15-2002, 10:19 AM
gertman's Avatar
NiCd's will give you alot more raw power!! BUT, run time will be even shorter.........my guess about 3 min.
New Article: Gertman's 4-cell Mod tinyrc Epoch RC1/43 Parts and Hop-Ups 24 12-25-2005 06:17 AM
"SuperCharged 5 Cell" SPEC2 SKYLINE GTR MicroRCracer Epoch RC1/43 Parts and Hop-Ups 40 04-10-2003 10:04 AM
