Old 11-10-2002, 09:27 AM
Aaronmamo's Avatar
Aaronmamo Aaronmamo is offline
Pro Tiny Rc Racer
For all you who do not understand how to lower the front of your car Read this
1. Take th body off of your car
2. Find the front tab of you car that locks into your body. (it is usually black)
3. Trace it on a piece of wood you plastic(the whole thing)
4. Cut it out with an x-acto knife or a scroll saw or any sharp thing.(do not cut yourslelf)
5. Line your cut out piece next to your original one o your car and make sure they line up exactly and are the exact same size. If they are different sand on it to make it perfect.
6. Sand off the TIP of the original tab on the front of your car.(the tap starts big and then gets small. MAKE SURE YOU ONLY SAND OFF THE SMALL PART)
7. Glue your piece right under your original tab with Super glue. Then put you body back on.
8. If it is not low enough make another tab and glue it on but make sure you sand off the small tab of the last one you did.
Old 11-10-2002, 12:02 PM
andy51289
Thanks, I think I finally get it now! Too bad it won't work w/ my fullsize wheelset...
Old 11-11-2002, 03:03 PM
Aaronmamo's Avatar
Pro Tiny Rc Racer
I think it will if you use a dremel and cut it out. But I am not sure. I still have to find out how to lower the back of a car. Does anyone know how to.
Old 11-11-2002, 10:53 PM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
Yeah, it's only one step too.
Step 1: Cut new slot in back of car.
Old 11-12-2002, 06:17 AM
DeeChan DeeChan is offline
http://groups.msn.com/TheAdmiralsLa...ry.msnw?Page=23
^^thats DriveWRX's site and where i found out how to lower the back of my car..thx Drive!!
I have the whole booster set for a ZZ but it doesn't have the stabalizers for sale. Email me for more info.
Antenna from RS-4$
Ripping off some useless controller plastic- negative 2$
getting 15'+ of range-priceless
Got my mini-x! A few criticisms/?'s... Bravin Neff Mini-X 9 12-31-2002 06:54 PM
How Do i Lower my car Sykoracer02 Bit Char-G Mods and Projects 3 11-30-2002 08:01 PM
lower your car with glue and sandpaper Chronic Bit Char-G Mods and Projects 13 11-08-2002 09:48 AM
Another Race car added to LP Racing latency ZipZaps 3 10-21-2002 09:03 PM
