Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Bit Char-G Gallery
Old 11-08-2002, 10:19 PM
GTR's Avatar
GTR GTR is offline
Bravely Runs Away Away!!
what to cut body with
hey, what do i cut the body with if i want to make a bigger hole for a second battery to stick out?
Old 11-09-2002, 06:52 AM
DeeChan DeeChan is offline
a razor or a dremel
I have the whole booster set for a ZZ but it doesn't have the stabalizers for sale. Email me for more info.
Antenna from RS-4$
Ripping off some useless controller plastic- negative 2$
getting 15'+ of range-priceless
Old 11-09-2002, 11:56 AM
Shacky Shacky is offline
I'm also interested in what people have found for this.
I've heard a hot xacto knife works pretty well. Can a dremel do precision cutting on the body for other, smaller, areas?
Old 11-09-2002, 12:09 PM
dremels move to fast i think to control for tight areas, Yes, hot exactos work well, keep some flame handy
Antenna from RS-4$
Old 11-10-2002, 01:29 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
yes a Dremel [or any small drill] and an exacto...
theres a trick i learned...
if you have a portable table lamp,
let your car sit near the light for ...i dunno a minute or two til it gets warm BUT NOT TOO LONG....and now the body is easier to cut....
like butta
Old 11-15-2002, 12:42 PM
Stridex's Avatar
Stridex Stridex is offline
Chunk
Tried the lamp idea yesterday. I did notice the difference. Great tip!
A religious war is like
children fighting over
who has the strongest
imaginary friend.
Old 11-15-2002, 10:53 PM
lunatic7 lunatic7 is offline
if making straight cuts you may consider a model saw or jewelers saw . a small very fine tooth saw. it leaves smoother edges.
BC's Xmod Masking/Painting Tutorial Bad Company XMODS Mods and Projects 30 07-15-2007 11:13 PM
Austin Martin DB5 body issue (a warning & a fix) rc+bass ZipZaps SE 13 05-23-2006 12:19 AM
Body Filler and Body Kits spamman ZipZaps Mods and Projects 2 02-18-2004 01:48 PM
is there any other way to lower ur car but not by tab lowering or dremal body cut.... eclipse98 ZipZaps 1 06-27-2003 08:35 PM
package body mod dtmracer ZipZaps 7 10-20-2002 09:03 PM
