11-07-2002, 04:15 PM
my digiQ is slower someone help
i jsut got my new digiQ and after the first charge it took off like a shot
but now after a couple charges its moving super slow
i checked the gears and what not and there is no fuzz or particals blocking them
it jsut seems like the car has less and less kick after every charge
and i have only had it since yesterday
also does anyone know of any codes for the digi Q
or even how to use them?
thanks
james
11-07-2002, 04:47 PM
You need a Special Controller to enter codes. Do you have one?
As far as your car slowing down, I would suspect it's not charging all the way...............maybe your remote batteries are dying.........maybe you are not letting the battereis die before recharging?
-Engineering Manager
11-07-2002, 07:35 PM
that or maybe u overcharged it too many times?
11-07-2002, 08:44 PM
no i just got it yesterday
the batteries are new
it worked good for three charges
it was considerably faster than any of my other tiny r/cs for those charges
so its not from long term battery misuse
how fast is the average digi Q?
and does it stay that fast?
maybe i jsut got a bad battery or something
anybody with any info please help
james
11-07-2002, 08:56 PM
well...the skylines are said to be the fastest....i have a pennzoil on the way...but my lancer would fly on my tiles in my basement...even in my garage....they pretty quik.....i suggest..drain the battery completely then give a charge
11-08-2002, 01:58 AM
besides trying to recondition your batts, dissamble the car and looka nd see if your batteries are leeking or something. To take apart the car, just unscrew the one screw in the bottom front of the car and the boddy pops off.
11-11-2002, 11:47 AM
i found the problem
nothing but hair and fuzz wound around the motor tip
i was checking the gears
but i had to take the gear tip off the motor
i think it was trying o weave a hat or something
thanks guys
11-11-2002, 01:20 PM
Just so you know, that is called a pinion gear
Glad you have your Digi Q back up to speed
11-13-2002, 03:38 PM
just clean ur digiq. some times theres someting stuck inside
my rice rockets: Xanavi Skyline with 3.0 engine,Lancewr Evo with 2.6 engine,Blue wrx DigiQ, pennzoilskyline DigiQ,Motorcycle GP,Mariobitchrg1.0,my nissan350z with 3.8nad finally my automodellista set.
