Old 11-07-2002, 02:18 PM
MR_SpaRkLes MR_SpaRkLes is offline
Send a message via AIM to MR_SpaRkLes
corrosion!?in my brand new bit!
ok so maybe its not brand new but a couple days old OEM clone. my steering electrode wires have some corrosion on them. is this what could be hurting my turning radious?????? it doesnt go all the way to the spindle but starts inside the brain box(where the battery etc. are i have no clue what you call it.) thnx
FOR SALE!!!!!
Solomon snow blades........$150
Technica boots size 10.5.......$75
PM me!
Old 11-07-2002, 02:20 PM
payaso payaso is offline
BIT PIMP
That sounds weird.. Where do you live?
silla
Old 11-07-2002, 02:23 PM
binaryterror's Avatar
Fear the 1's and 0's
On all my Bits/MS's there is either a black or white coating (sparse, but there) on the return lines from my steering coils. This is done most likely to distinguish the 2 wires...
just my thoughts.
Old 11-07-2002, 02:38 PM
cincinnati ohio, and its not on all four but its on two of them. it doesnt look like its intentional. i dont get it. its a pretty big mess in there. i wanna get my hands on a solder gun and re wire. theres alot jumbled up that i think can be straitened out to make it easier in the future to work on. i really dont understand why this stuff is on here though. hmmmmmmmmmm
if i find a thicker gause wire can i use that for the steering wirers????? these look so brittle im afraid ill break them. and is this just copper wire????
FOR SALE!!!!!
PM me!
Old 11-07-2002, 02:59 PM
mikey-flies
I've seen this on one of mine as well. This could be similar to the black wire corrosion that destroys R/C battery packs. I hope not, because I haven't heard of a cure other than removing the offending wire :/
Old 11-07-2002, 03:13 PM
booooh on that idea haha. hmmmm is there a such thing as swapping out steering coils for bigger gauge more powerfull ones????
FOR SALE!!!!!
PM me!
Old 11-07-2002, 03:42 PM
Bryan4691's Avatar
Bryan4691 Bryan4691 is offline
Asia-Link Racing
The corrosion could be caused by how the bits are shipped in from China. My company ships many things from China and i have seen corrosion due the salt in the air when shipped sea.
Old 11-07-2002, 04:28 PM
rud0g rud0g is offline
Larger wires won't necessarily do any good, the magnetic field generated by the coils is dependent on the current from the system, so if you push more current the field will be stronger but then you have to figure out what these tiny wires are rated to handle too.
It would be Sad/Hilarious to go through the work of bumping up the current through the wires only to burn the shellac off of them and start a car fire.
problem is the strength of the magnetic field also depends greatly on how many coils of wire are present/the proximity of those coils to one another/the diameter of the coils, etc.etc.etc.
your safest bet would probably be to remove the affected portion of the wires as they probably ARE corroded due to poor quality control (i.e. the shellac on the wire is to thin to prevent the oxidation of the wire) and then solder some 28-26awg stranded/insulated wire from the coil to the PCB
good luck
If you're not living on the edge, then you're taking up too much space.
Old 11-07-2002, 07:25 PM
sweet. thanxs very much.
FOR SALE!!!!!
PM me!
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 11:04 PM
Bit tires vs Microsizers tires Dys70pia Bit Char-G Parts and Hop-Ups 3 12-28-2002 04:34 AM
Entire Bit collection for Sale (Customized Bits) bitfreak Bit Char-G / MicroSizers 10 09-13-2002 08:28 PM
