Old 11-01-2002, 12:31 AM
_NiTrOuS_'s Avatar
_NiTrOuS_ _NiTrOuS_ is offline
Antenna
If you want to install a new anntenna to your bit, on the chassis, do you need to solder with copper? Cause I ruined my old one because I tried it with normal metal, didnt work, then re-soldered it with copper, and it did, but a tiny wire inside snapped off the board. Are u supposed to solder with copper?
Old 11-01-2002, 01:23 AM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
solder with copper??? NO NO NO!! Solder with SOLDER!!! Try resin core solder and se flux to help the solder flow.
SPEED-The state of being in rapid motion
need a new TX antenna? TypeZer0 XMODS Parts and Hop-Ups 3 02-15-2004 07:09 AM
Alternate antenna ideas! caver01 Bit Science 214 11-07-2003 09:38 PM
Antenna Support System got BITS? Bit Char-G / MicroSizers 7 03-27-2003 11:25 AM
stock antenna lenght big-key Bit Char-G / MicroSizers 3 02-23-2003 11:39 AM
ZipZaps: Antenna Mod pics available in Gallery Namuna Bit Char-G Mods and Projects 2 09-25-2002 11:13 AM
