10-29-2002, 11:15 PM
The online drunk
Threw the zip away
I was trying the dual bat mod and the blue wire broke off of the curcuit board. Then I pulled the rest of the blue wire off of the metal plate that goes to the motor, so I could put a new(longer)wire on it. I put the new wire on it and my bugar solder on the metal plate wouldn't let the motor sit in properly. Then I noticed that only a couple strands of wire were soldered to the curcuit board. I got pissed off and ripped the whole curcuit board off the chassis and threw it away. I am now going to go out and buy a microsizer(being none of the radio shacks have the ZZ anymore). I have two bats, the red ZZ motor, and the 2.6/3.2/3.8 motors. I am honestly proud of myself because normally I would have smashed the ZZ under my foot, right when the wire broke. I will buy another ZZ if I find one, being I have a Mustang body with the side and rear windows cut out, anxiously waiting for a home. Sorry for the long thread, Mike.
10-30-2002, 12:36 AM
Wanna Drag??
I would have bought it from you for $15. The wiring is fixable.
"Going to war without France is like going deer hunting without an accordion. You just leave a lot of useless noisy baggage behind.
-Jed Babbin
10-30-2002, 03:45 AM
www.d1gp.com
mwhahhah somewhat of a same incident happend to me
i tried the dual battery mod to make it fit inside the chassis with some cutting..and so i cut, and so some wires came off...
when i soldered one wire back on, another came off...and this kept happening..
the charger tabs are really annoying too, kept coming out of place...
now my ZZ sits on the floor, with pcb exposed, no rims, no wheels, no body.....im not sure if i want to fix it at all...
if anyone wants my dead ZZ chassis that has wires broken etc....
lemme know..
metalmarkara@aol.com
10-30-2002, 08:43 AM
Microrcfool
I'd take it.  parts are cool
"What's a low fool?" lol
10-30-2002, 09:39 AM
i got a zz chassis with the board intact that ill sell. ill warn you that your rear axle is gona slip out every 2 mins
10-30-2002, 12:35 PM
The online drunk
I might try hacking it back together. (gonna go garbage picken  )
edit : I found it. Tonight I'll start the repairs.
10-30-2002, 04:06 PM
Hogjowls why don't you use tinfoil so you rear end doesn't slip...
10-30-2002, 04:19 PM
4r3 j00 ub3r l337 h4xx0r?
Timmz, ive also got one of the broken rear axle cars. Tin foil will fix it for about 1/2 a run... and even with it, it KILLS you cars speed
Shiggity Shiggity Shwa.
10-30-2002, 05:07 PM
fixing the rear axle slip problem
my rear axle is currently being held in place by a match stick.
I just cut it to the right length then made it thinner a bit by pealing a layer of the paper off.
It seems to be working great for me.
i have pictures but i forgot the USB cable for my camera today.
if anyone wants to see i'll post them.
-ts
10-30-2002, 07:34 PM
ZipZap Maniac
A way to fix the reax axle concern is to use gel type krazy glue and to put just a dab on the par of the chasis that is worn. the reason for using the the gel type glue is it can be sculpted so the fit is not too tight. This fix works great! And if and when it wears again just do the repair again.
1999 Super Modified Zinc Yellow SVT Mustang ZZ
Bit PCB MOD
It's a sleeper! hehehehe
M/S Mitsubishi EVO Lancer w/modified clone motor
M/S Nissan Skyline
M/S Honda S2000
10-30-2002, 07:51 PM
BLWNSTNG, I think you need to practice patience if you plan on jumping into modding things. Breaking stuff when you mess up seems kinda childish. I'm not trying to pick on you or anything, but that scenario kinda reminded me of the time a friend of mine was trying to change a tire on my uncles car while my uncle was sitting in it stuck on the highway. Anyway my friend broke the tire iron in the process and got really mad, he pulled out a gun and shot my uncle in his a s s . My uncles ass hasn't been the same ever since and he's really pisssed about it.
Thanks
I made that up.
10-30-2002, 07:54 PM
1: foil from a pack of smokes works sort of but its a pain.
2: glue worked for about a day
3: i have a car with a way better drive train so im not that concerned about it at the moment
10-30-2002, 09:01 PM
Ill choke slam you!!
I had several probllems w/wires when i first started tinkering, i after a whole lot of work i was able to salvage 6 cars, all very fast, however the zips are only fast because i did swapped pcbs from a bit into the zip, anyone with a bit pcb and a zip, its well worth the trouble, my fast and furious zip with bit pcb and nos motor is tooo fast. it spins out like a bit would even with the additional weight. its too fast for my track so i use it as a drag racer..(straight only)
Flamin Dynamite Rocket Racer(7.2)
Honda Epoch Indoor racer 1/43(4 cell)
Auldey Tin Racer 1/32(on the way)
1/10th Traxxas Rustler(Elec)
MS Mitsubishi Lancer
MS Blue WRX
Custom spider mobile bit
orange ff zip w/ bit pcb(2 cell)
green ff zip w/shen pcb(3 cell!!)
2 Shen Qi Wei knockoffs
Walgreens Knock off Celica
10-30-2002, 09:04 PM
ZipZap Maniac
I agree with you natedogg I did that PCB swap too and like the way the zip handles way better than my MS It was well worth wasting a bit for.
Bit PCB MOD
M/S Nissan Skyline
M/S Honda S2000
10-30-2002, 09:13 PM
Marc, i dont know why but i can handle my bits at top speed around corners much better than my modded zip, it spins put over and over, it has the good grip tires on it, just way too mush torque, i think maybe if i use the green gears itll help a little, i havent tried yet, i just love how fast it is that i havent tinkered with it since the mod.
MS Blue WRX
