10-29-2002, 03:41 PM
how do i make my microsizer do this?
i just bought a RX-7 MS and ive only untied the knot and put in the green ZZ gear so far and i can do pretty good donuts and can peel out in reverse, but, what do i nee dto do to peel out in forward?
10-29-2002, 04:08 PM
Dude i tried to hit ya on microcars but they closed your post?? Anyway, get yourself one of two or both motors for the zipzaps. NOS and TURBO. Drop the Turbo in the sizer and watch it scream, do doughnuts and mine almost flips if i put some biting tires on it.
Drop the NOS in there....hard to control. Every turn is a doughnut lol
BTW are you one of them freaks from stangnet
10-29-2002, 04:25 PM
thanks!
yep, im mustangfreak_01 from stangnet. i post on ALOT of mustang boards
10-29-2002, 04:27 PM
I knew it cus I live at stangnet PEWTERPONY
02 min grey coupe
10-29-2002, 04:36 PM
02 min grey coupe
nice! to bad MG is no more
btw how do i get this darn red motor into the MS?!?!?!
10-29-2002, 04:40 PM
Cory, you just have to work it in. If not you can drimmel out the body like I did to a couple of my cars.. Well I actually used a soldering iron.
10-29-2002, 04:43 PM
Barry I meant to ask you about that mod. Can you re-use your bit motors with that altercation.
All I did was bend up my heat sink.
10-29-2002, 04:46 PM
welli finally got it in there! i took it for a spin and the sucker flipped over when turning!  and thats with green gears!  im gonna try red now
10-29-2002, 04:54 PM
Yes the bit motor still fits fine.
10-29-2002, 05:03 PM
red didmt do much, and the stock orange gears dont peel out in forward ether
10-29-2002, 05:08 PM
Red would make it harder to peel out. Also what tires and what type of surface are you running on? and why is it so important that it peels out. Spinning the tires will make the car go slower.
10-29-2002, 05:15 PM
l33t camber wizard :)
My zipzap motors fit in my Bit with NO issues whatsoever. It's tight but it fits...
10-29-2002, 05:19 PM
i dont know :dunno: just wanted to make it peel out i guess  but the blue gear made it easier to peel out in reverse and could do it a little in foward.
i found somethin out to, i can control my MS with my ZZ controler (both 27mhz) but, the foward and reverse are backwards!
li also ran into a wall by accident, and the wing came, off. i must say it looks alot better wingless
10-29-2002, 05:22 PM
I had to mod 2 of my microsizers to get the ZZ motors to fit, but my other microsizer and Bit Char-G have no problems fitting the ZZ motors. I guess its the luck of the draw.
10-29-2002, 08:40 PM
oh yeah! im running the slicks and i race it on the kitchen floor.
