10-29-2002, 09:12 AM
Big kid
Great success with antenna mod!
I just added a telescopic antenna to my tranmitter, and a solid copper antenna to my 27MHz MicroSizer last night. I added 16 feet to my starting range of 6 feet!
I found that a solid core copper wire gave the best results as a car antenna. I found that the small gauge copper wire that is in the middle of cable TV cabling (co-axial cable) is perfect! Strip off all the outer insulation and braided wiring, and you are left with a nice fine copper wire. IMO it looks better on the car with no ugly insulation around it to detract from the car.
It extends about 5 inches above the car, and now my total range with this 27MHz is about 22 - 25 feet indoors!
11-01-2002, 03:27 PM
dam...good range there buddy..i need more range
11-01-2002, 04:36 PM
I have done the same thing and might have gotten enven better range but I ran out of apartment so tonight I will test it out on the campus parking lots when the crowd clears out.
Bit Char G, Blue Skyline GT-R, 2.6 KIT
Microsizer, WRX won microsizers.com
Micro Q, F360 Modena, Working on it
Castrol Supra Body, Mobil Nsx Body
11-01-2002, 06:20 PM
Indoors vs Outside
I think you will find that outdoors you have MUCH better range. Has to do with interference I guess, but outside, my car can go 50 feet or more. Inside, it's a totally different story. If you get good range outside, be sure to qualify the numbers with the fact that it was outside.
11-02-2002, 06:15 PM
Big kid
No crip-cap in any of the controllers I have. Just car and transmitter antenna mod for me.
11-03-2002, 12:57 AM
Yeah I removed the cripple before right after I put the car together.
