Old 10-28-2002, 04:51 PM
natedogg4674's Avatar
natedogg4674 natedogg4674 is offline
Ill choke slam you!!
controller mod
i just recently finally found a place to get the real bit charg g. i got the honda nsx on 27 mhz, terrible range, so i did the car antenna mod i do with all my cars, it helped a little but still not good enough. So i decided to rip into the controller to see whats going on in there. i noticed that the wire antenna isnt even actually attached to the pcb, its just pinched into place on the bracket so the antenna can be wound up. So i decided to completely take the wind up antenna out and modify it with a radio shack telescopic antenna, about 22 inches. The way I did this was melt a section of the top of the controller out right where the screw is that holds down the antenna bracket. then screw the new antenna down with the stock bracket and screw, put it all back together and improved range greatly. Ive noticed that with all my cars that the 27 mhz just seems to not work as well, it must be because other appliances and such have a frequency close to that. PS I was going to do the crip cap mod, but my controller doesnt have one.
Old 10-28-2002, 05:57 PM
shred shred is offline
shredding the masses
i bought a 27 mhz zipzap and took it back for a microsizer 49 mhz
out of the box my microsizer had 50 ft outdoor range.
after i did a controller mod (CAT5) i got 52 ft indoor range.
Old 10-28-2002, 07:12 PM
cat 5
whats the cat 5 mod, and where do i get it
Flamin Dynamite Rocket Racer(7.2)
Honda Epoch Indoor racer 1/43(4 cell)
Auldey Tin Racer 1/32(on the way)
1/10th Traxxas Rustler(Elec)
MS Mitsubishi Lancer
MS Blue WRX
Custom spider mobile bit
orange ff zip w/ bit pcb(2 cell)
green ff zip w/shen pcb(3 cell!!)
2 Shen Qi Wei knockoffs
Walgreens Knock off Celica
Old 10-29-2002, 01:19 AM
tifosi_ms1 tifosi_ms1 is offline
You unsolder the existing antenna and replace it with a cat-5 cables wire (one of the eight) it looks a lot better and reception is improved. Get commercial grade with the blue casing. Home Depot $.22 per foot. Addtional notes at QFM.
Old 10-29-2002, 03:49 AM
QFM Racing's Avatar
QFM Racing QFM Racing is offline
Moderator - Modifier
Telescopic antenna $6
4 color antenna pack $1
Go to QFM Racing
QuestForMadness.com
QFM Racing's Custom Bit Modifieds (The Bit How-To Page)
http://questformadness.com
controller antenna mod chilli_mp138 ZipZaps Mods and Projects 0 03-25-2005 11:30 PM
controller mod natedogg4674 ZipZaps 2 01-10-2003 01:27 PM
NEW CONTROLLER MOD! Check it out.... mike_diaz19 Bit Char-G / MicroSizers 13 12-19-2002 12:02 AM
controller mod & solution for poor range natedogg4674 ZipZaps 4 10-13-2002 10:40 PM
cheap zz controller joystick mod lnx_author ZipZaps 12 10-13-2002 01:21 PM
