10-27-2002, 11:19 PM
body off-center
maybe its just me, but my MS looks like it has its body offcenter.
Both of my MS are like this, is this supposed to be like this, is it a common problem, or am i just unlucky?
chassis=Tomy 35 MHz 2-Spd
body=Silver Nissan 350Z
motor=ZZ NX
(Lambo set in the mail)
10-27-2002, 11:27 PM
It's super useless!
Odd. Mine is off by like a 1mm but my front tab is about 1mm shorter than the slot.
Maybe your axle is misleading you. Push the axle all the way in from the left side.
10-27-2002, 11:45 PM
thanks dookie but that doesnt seem to do anything
motor=ZZ NX
10-27-2002, 11:55 PM
SpeedFreak
as long as it doesnt mess up your performance, dont worry about it.
10-28-2002, 12:44 AM
yellow fish forever!
my WRX does that in the other direction, but both of my skylines are straight...dunno whats up about that. it varies from body to body i think. Non-fun.
10-28-2002, 06:00 PM
I'm 1337 r/c'er :)
i think the people who make the bodies should get a better mold. The body i have (lancer) seems to have a crude gash on the trunk of the car , anyone else have this problem?
10-28-2002, 07:55 PM
I'm The Youngin' of R/C
My Bit Char-G Trueno is fine! I wonder if it is just Hobbic or sompin'?! Because it wouldn't be an import from Tomy. The Hobbico shop would reproduce them, but they wouldn't be perfectly identical ya know!
Hey Officer, Did You Stop At The Donut Shop On The Way Here?
10-28-2002, 09:56 PM
Same here
Yup -- my blue Subaru Impreza has both the crude gash on the trunk AND a body that is off-center to the right.
10-28-2002, 10:18 PM
I'm 1337 r/c'er :)
maybe it's a hobbico thing.... well if all the jdm are fine maybe i'll get someone in hk to send bodies to me instead of buying the hobbico versions.
10-29-2002, 12:29 PM
My idential blue skyline is also off to the drivers side but it is ever so slightly. And ther front tabe is slightly smaller then the opening and the "gap" (as it sit in the chassi is on the drivers side.
10-29-2002, 12:55 PM
Fear the 1's and 0's
Hobbico doesnt remake the bodies, they are the same bodies from Tomy.
Read the FAQ, Tomy makes the MS's. Hobbico is only a distributor, hobbico doesn't repackage them most likely, Tomy does it for a fee.
I have 2 Skylines, 1 is the claer booster and the other is a MS white. they are both close to center, one is off to the left and 1 to the right.
thinking more clearly, the axle is pressed into the wheels, who says those are exact everytime? also maybe it is the tab on the chassis along with the slot in the body. being in manufacturing chances are these molds are old or just off and YES it does happen.
10-29-2002, 05:25 PM
deviant bit char-g pro
I think your all just seeing things.
Heres a fact:
The side of the axle that has the gear pressed onto it with the wheel always sticks out slightly more than the other side of the axle with out the gear. As binaryterror noted above the wheels are pressed onto the axle, and are not exact every time. I noticed this on Tomy Bits/Microsizers, and many oems(clones), the Z cars, Smartland IR(not a clone), and the Micro thunder racing cars(z car type clone).
Take a close look at the pictures posted previuosly. You will notice its the wheel with the gear that sticks out of the body slightly, while on the other side the wheel doesn't stick out. Also turn the car over and notice the space between the body and both sides of the chassis. They are both the same which supports my theory that its the axle not the body that is off center.
