Old 10-27-2002, 06:52 PM
BackInBlack's Avatar
BackInBlack BackInBlack is offline
MyMicrosUnderTheFridge...
Where's Waldo? (Or: Find the cripple cap...)
Would someone be so kind as to point out where my transmitter cripple cap is? I found the one in the car, and removed it, but I fail to see which cap is the offending one in the transmitter...
Old 10-27-2002, 06:53 PM
Here's the other side of the PCB:
Old 10-27-2002, 07:32 PM
lanevo7 lanevo7 is offline
hey, doesn't look like you have one on that side....can you take a pic of the other side?
if ur getting really bad range...then i'm guessing there should be one capacitor oddly out of place on the other side of ur board
Old 10-27-2002, 07:37 PM
Sorry about that, I uploaded the wrong second photo. It has been rectified...
Old 10-28-2002, 08:29 AM
cowfish_29's Avatar
yellow fish forever!
i have read that those generation of controllers often don't have the caps in them..what kinda car did it come with?
Old 10-28-2002, 06:00 PM
We have two: White Nissan Skyline (49Mhz) and Red Mazda RX-7 (27Mhz).
Old 10-28-2002, 07:21 PM
It appears to me that capacitor C8 couples the antenna signal to common. Could this be it??? Can anyone confirm?
Old 10-28-2002, 10:01 PM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
how good is the range on the 49Mhz. My White 49Mhz skyline has pretty good range indoors about 20 stutter free feet!!! I've found the crip cap on the PCB of the car, but i don't want to mess with that.
Old 10-28-2002, 10:15 PM
Out-of-the-box, I'd guess 5 feet maybe? Both cars really lack in range. After removing the cars' SMT cripple caps, they got considerably better, but not more than 10 feet or so. After removing the knot in the receiver wires, and changing the transmitter antenna, we got about 10-12 feet before the infamous studder and loss of control. It is quite possible that the environment here is causing most of my problems, as we currently live in a condo. The closing on our new house is in 2 weeks, so I'll try them out on the wood floor there and check back in here. I guess I'm just used to my T3 truck that has a range of a 1/4 mile...
Old 11-29-2002, 08:42 PM
I really hate to TTT, but...
Old 11-29-2002, 08:53 PM
SPEED's Avatar
SPEED IS GOOD
ok well, i had to get a replacment chassis because the motor tab on mine busted and i accident;y dropped it tweaking the chassis pretty bad. Well for some reason my new chassis wasn't as great with the range as the last. I found some Solid copper wire in my house and used that. Now my range was better, even better than the last chassis. I deffinetly reccomend doing the CAT 5 mod or somthing similar. It's not to hard to do is you already did the TX mod. I even went ahead and resoldered all the wires on the PCB to red and Black wires .
The environment can be the problem. I hacve noticed that driving in a cluddered area can cause poor range. But try the CAT 5 mod, it will really increase the range.
SPEED-The state of being in rapid motion
u have a 27mhz skyline(white) cant find cripple cap pakiplaya Bit Char-G Mods and Projects 1 12-16-2002 02:18 AM
Where is the cripple cap on the 27mhz skyline(white) pakiplaya Bit Char-G / MicroSizers 4 12-15-2002 10:32 PM
MicroSizer Cripple Cap Rcdude7378 Bit Char-G / MicroSizers 2 10-22-2002 10:48 PM
US Microsizer Cripple Cap. Is there a difference? efferfax Bit Char-G / MicroSizers 0 10-02-2002 01:16 PM
Possible Cripple Cap.. Look at the pic! retroicon Bit Char-G / MicroSizers 3 09-07-2002 11:56 PM
