Go Back   TinyRC.com > 1/24 and Smaller > Losi > Losi 1/24 4WD Rally Car
Closed Thread
Old 08-03-2010, 10:07 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
1/24 4WD Rally Car RTR
Key Features
-Innovative micro 4X4 chassis
-Simple bottom load battery compartment
-Threaded oil-filled, coil-over shocks
-2-in-1 ESC/receiver combo unit
-Losi 27MHz AM radio system
-High capacity 220mAh NiMH rechargeable battery pack with included wall charger
-Powerful, installed micro motor
-Threaded axels
-Shaft-driven transmission gear differential
-Micro all-terrain rally car tires
-Gold or black rally wheels
-Side nerf bars for collision protection
-Fully decorated rally car body available in Gray & White, Orange & White, Blue Splatter and Red Splatter
Rally like never before with the Micro Rally Car. The world’s smallest 4WD rally car comes with everything you need—you’re ready to run right out of the box. It features scale details, including a rally-inspired body shape, micro all-terrain tires and detailed wheels. It’s so realistic, you’ll almost forget it’s a micro. But don’t let the size fool you—the Micro Rally Car is ready to conquer. Wherever you run it, indoors or out, this car will tear up any terrain.
Specs
Type: 4WD Rally Car
Scale: 1/24
Length: 6.42 in (163mm)
Width: 3.72 in (94.5mm)
Wheelbase: 3.9 in (99mm
Weight: 5.3 oz (160 g)
Chassis: Durable molded composite
Suspension: 4-wheel independent
Drivetrain: 4WD shaft driven
Tire Type: Rally car tread pattern
Radio: Losi 27MHz AM radio system
Batteries: 4.8V 220mAh NiMH
Charger: NiMH Wall Charger
Kit/RTR: RTR
Shock Type: Threaded, oil-filled, coil-over
Body: Fully decorated and painted (available in Gray & White, Orange & White, Blue Splatter and Red Splatter)
Micro Rally Car RTR User Manual
Micro Rally Car RTR Parts Explosion
Warranty Period:
Exclusive Warranty- Horizon Hobby, Inc., (Horizon) warranties that the Products purchased (the "Product") will be free from defects in materials and workmanship at the date of purchase by the Purchaser.
Closed Thread
