Go Back   TinyRC.com > 1/43 and Smaller > Kyosho dNaNo > Kyosho dNaNo Parts and Hop-Ups
Old 04-03-2010, 07:40 AM
MrNanoTrax's Avatar
Arrow X-Power Releases for April 2010
just dropped a few new items and all photos have been updated.
Ball Differential
very similar to the one from Kyosho but it includes all Ceramic Diff Balls
Wheels (3 Styles)
same styles that are available in Aluminum from PN Racing but they're plastic and come in all the original Kyosho wheel colors.
Differential Gears Set
if you're into tuning your gear ratio, this is a good pick up as it contains 5 spur gears: 30T,31T,32T,33T & 34T
Pinion Gears (7T/8T)
if you don't want to have to buy a whole set with tools and everything + gears you don't normally use, pick up this 2-pc set that includes only the most commonly used pinion gears
of course, all of this & more now available in the X-Power Parts Section @ NT
Old 04-03-2010, 08:59 AM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
qon, would you like an x-power vendor forum? you would be setup as the moderator for it. let me know if interested.
i am very much waiting for opinions on the ball diff, compared to kyosho and atomic.
Old 04-03-2010, 10:03 AM
MrNanoTrax's Avatar
nah, that's cool... i probably should've just added to your original thread i've tried the xp ball diff on 2 of my cars. no need to include atomic in the class of the X-Power & Kyosho diffs imo. x-power's diff is very similar in many ways but has ceramic ball bearings included, gives more gearing options with more available spurs and its very smooth so you'll need to tune with more dense oils (7k+). if you don't like it's pressure plates, they are interchangeable with the Kyosho pressure plates. the set doesn't come with 'construction' tools or instructions so i'd say they assume if you buy it, you know what you're doing
Last edited by MrNanoTrax; 04-03-2010 at 10:31 AM. Reason: fixing my typos & screw ups
Old 04-03-2010, 10:29 AM
arch2b's Avatar
nah, don't worry about it. i'll update the stick parts thread.
just glad to have you hear to share the news
Tags
dnano parts, x-power
