Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Bit Char-G Gallery
Old 10-24-2002, 10:52 PM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
Project Track GT-R (2nd stage)
Pics, explanation in last post...
Old 10-24-2002, 10:53 PM
NorCalCoug's Avatar
NorCalCoug's Avatar
Old 10-24-2002, 10:54 PM
NorCalCoug's Avatar
Old 10-24-2002, 10:55 PM
NorCalCoug's Avatar
Camber baby, ya hear me?
Old 10-24-2002, 11:01 PM
NorCalCoug's Avatar
Mods so far:
Body lightened (sanded out inside about a third of the body thickness)
Rims chopped to 4-spoke (less reciprocating mass)
Slammed body (cut new slots front and rear)
Shaved out wheel wells to fit wheels when lowered.
Majorly cambered front wheels.
Chassis shaved to lighten.
PCB cover removed
Antenna pig-tailed.
Pearl blue metallic paint.
What's coming up:
Shave out windows to lighten even more.
Remove paint from headlights and tailligihts for painting or possible LEDs for 'show' when not racing.
Notes on mods:
Paint looks much better in person than in pictures; I guess with macro zoomed in that much it's easy to spot every imperfection.
Negative camber on front wheels (VERY hard to do) is functional and helps with cornering ALOT. The rear slides out a bit too easy; that was remedied with the 'performance' treaded tires from a zip zap wheel/tire kit. I didn't try this with anything larger than my 1.6 motor yet though. I fear on the 3.8 it might be a bit too much and send the car spinning out... Oh well!
Old 10-24-2002, 11:28 PM
323iT's Avatar
323iT 323iT is offline
Send a message via AIM to 323iT
very cool idea with the camber!!! how did you do it? if you don't mind telling us does it help with the handling?
Old 10-25-2002, 12:36 AM
NorCalCoug's Avatar
I'd like to perfect the method a bit before I release a real how-to on it, with pictures. I do get a little bit of tire-rub on the inside of the tire against the steering arm right now (despite having shaved it down to almost breaking) so my methods are not yet perfect. I -may- have to custom make the steering arms out of a non-ferrous metal like billet aluminum (I have access to a HAAS mill and lathe) that would be light-weight enough but still function correctly.
Basic how-to (I take NO responsibility of you screw it, it is easy to TOAST your bit this way ), you have to re-drill new holes for the 'upper strut' of each steering knuckle that are moved inwards towards the body slightly. It's okay to siamese the hole with the existing hole as long as there isn't enough play for the 'strut' to slide back into the original hole. Now the fun part. You have to widen the hole in the steering arm by cutting towards the center of the arm. Careful when doing this, it's easy to crack the plastic. You'll also have to sand or file down the outer edges of the steering arm otherwise it'll rub against the inner side of the tire. If you don't adjust the steering arm, it'll be hard to turn, and you'll have MASSIVE toe-in, which will make your car plow and slow it down.
Old 10-25-2002, 01:42 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
whoa..the rims look ALOT better for some reason....they look shiny
and im guessing you havent taken the masking tape off right? thats what it looks like
haha i did the camber thing a while back with my original front bit tires...but bad results...i got wobbly wheels....
Old 10-25-2002, 09:07 AM
NorCalCoug's Avatar
Well, originally I had the windows masked off when I painted it metallic black. But I decided to repaint, so I paint-thinnered the whole car and decided that I wanted to cut the windows out anyway, so I didn't need to mask them off. Rims look shiny because it's a different set; the set in the first series of pictures were just there so I could test the drop. I'm going to make a 2nd set of rims that will be painted flat black (race style) for racing; leave these chromed out for 'show'.
Old 10-26-2002, 03:48 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Wow, great job - love the camber!
Old 10-26-2002, 04:53 PM
NorCalCoug's Avatar
Thanks, I gotta get a couple more steering arms to do some testing with (I broke this one just this morning) before I can really test it out with a fast motor. Anyone got some broken bit chassis they wanna send me? I'll pay 1 dollar per broken chassis + postage!
Old 10-26-2002, 09:19 PM
jaubery jaubery is offline
The camber mod looks great! I would be interested in the possibility of doing this to the rear. That's where all my bits could use the extra grip the camber would provide. I imagine that would be very difficult to do with the straight axel.
Old 10-27-2002, 03:24 AM
GT-ahh GT-ahh is offline
does the camber mod make drifting easier? cause with real cars high camber makes the tyre right itself when the car rolls and it helps drifting..
if you dont like my driving, get off the footpath!
Old 10-27-2002, 12:11 PM
NorCalCoug's Avatar
I broke my camber-adjusted steering arm. No more testing for me. Gotta find another spare steering arm first... all of mine have already been trashed for testing except the one in my Z booster but I'm not gonna touch that.
motorcycle track project mitchell Bit Char-G Mini GP Motorcycle 0 10-07-2003 04:10 PM
Modular Cardboard Track Component Project john Tracks 24 12-13-2002 11:55 AM
Project Track GT-R (Stage 3) NorCalCoug Bit Char-G Gallery 20 10-27-2002 01:45 AM
Project Track GT-R (In progress) NorCalCoug Bit Char-G Gallery 16 10-23-2002 10:48 PM
Final stage of Lexan Project body for Zip Zaps ICH_BIN_GUT! ZipZaps 12 10-21-2002 09:25 AM
