This is quite an informative board and I figured I'd ask my question here. I just want to know what types of tools do you guys have in your bit char-g tool kits? let me know the most important ones. Most specifically, however, I want to do the antenna through the hood mod and drill a small hole. What type of drill do you use with very small drill-bits like that? Does a dremel have small drill bit attatchments or some other power drill? any advice would help thanks guys.
Small screwdrivers, needle-nose pliers, wire cutters, and a good soldering station. The dremel is a good idea if you're going to be doing body mods and I'm pretty sure you can get a chuck for small drill bits.
BTW - I got my soldering iron from Circuit Specialists. They have good prices on stuff.
