Go Back   TinyRC.com > 1/43 and Smaller > Kyosho dNaNo > Kyosho dNaNo Parts and Hop-Ups
Old 12-15-2009, 03:13 PM
XStream's Avatar
XStream XStream is offline
Kyosho tires vs PN Racing tires
I've got three questions:
1: How can I compare the Kyosho #10 or #20 tires with the PN Racing "degree" notation?
2: Which kyosho tires come with a stock dnano? (I don't find this in the dnano specs sheet)
3: For what stands FRA / RA (Front / rear? and the "A"?)
I'm currently running with the stock tires in front and softer tires on the rear (FRA#20 or RA#10, depending on the result of question 3 since i don't remember which tires came with one of the two packs ) But I want to order PN Racing tires with a compound that are almost the same.
Thx in advance!
Old 12-16-2009, 02:23 AM
MrNanoTrax's Avatar
how exactly are you staying on 4 wheels with tires that soft in the front?? stock tires are listed in the Optional Parts & Technical Data sheet and in your individual car data sheet also posted on the Kyosho dNaNo Support page (#50F, #10R). FRA (front/rear narrow) /FA (front standard) /RA (rear standard) are codes for the width of the tire/wheel. there's no way to 'compare' the rubber (that i know of other than just trying them) but generally tire compounds are very similar across brands.
Old 12-16-2009, 10:03 AM
XStream's Avatar
In the first post I stated that I was driving with the stock front #50 and rear #10 but actually I'm driving with FRA#20 (which is indeed much softer) and RA#10 which gives me the best result with the current possible combinations. (at least on the kyosho dnano home circuit)
