Old 09-04-2009, 09:39 AM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
Mr-03
Chassis Configurations
High-Mount Motor Mount: oOn the HM chassis, the motor is mounted
MM chassis/ Mid-ship Motor Mount: On the MM chassis, the motor is mounted mid-ships directly in front of the rear axle. Mass is concentrated in the center and produces good agility and a shorter rear overhang.
RM chassis/ Rear Motor Mount: On the RM chassis, the motor is mounted behind the rear axle. Positioning the C of G at the rear produces high levels of traction. This makes tail control all the more interesting. RML chassis omits the top damper to generate lower chassis height for the RM chassis.
LM chassis/ Mid-shop Low Motor Mount: Latest chassis design is the fastest MINI-Z Racer ever. With the motor mounted 5.5mm lower on the 3L size long wheelbase chassis (compared to the MM motor case), the motor can be positioned much closer to the lateral center. The stability of the chassis has dramatically improved with small diameter wheels, newly designed front knuckles, a 1mm lower chassis and a friction damper now standard.
the formal conversation on the developments seen in this new chassis platform can be found on our sister site, Mini-ZRacer.com.
Old 08-07-2010, 06:14 AM
silverb silverb is offline
Differences from older chassis
Hi I'm very interested in the hobby (currently unable to obtain a mini z). Just wondering if how different is its performance is from the mr-02 and are there many parts that do not interchangeable?
finally, if I'm to get one, which one should I get?
Thank you for your advices!!
Old 08-08-2010, 04:28 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Welcome to the forums silverb - take a look at the thread Arch2B linked to above to get started - then I'd suggest you post your questions on our sister site, Mini-ZRacer.com, where there are thousands of Mini-Z experts and enthusiasts who can help you out! If you have questions about specific products or would like us to put a start package together for you, open a Support Ticket at the Shop and we'll get you taken care of. Thanks!
