Go Back   TinyRC.com > Manufacturers > RCP Tracks
Closed Thread
Old 05-07-2009, 07:50 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
RCP Tracks Products
RCP Tracks can be purchased from the shop, Shop.TinyRC.com for both Continental US and International Customers. RCP Tracks also has a directory of official distributors.
All RCP Tracks sold in the US are drop shipped from our warehouse. If a specific track is in stock at our warehouse, than all US distributors, dealers and stores have it in stock. Check our "Stock Status" page for day to day stock status.
RCP Tracks 30cm Tracks
RCP Tracks Mini-96
Part # 13096
The Mini-96 is a unique track that uses smaller tiles to allow for longer road courses in limited spaces. The Mini-96 track measures 7’ 9” X 11’ 8” and can be used by itself or combined with other tracks to create larger and more challenging road courses. The track lane width is approx. 19” wide from inside to inside rail. This track is not recommended for beginners unless the RCP expansion kit is purchased to widen the lane width. Everything is included in the Mini-96 kit to create the layout shown in adjacent picture. No additional pieces are needed. Kit includes 1 1/8” tall soft side rails and strong threaded attachment pins that secure the rails to the track. No need to worry about the rails coming off from car impacts. You can remove the rails after use or store them with the rails connected for faster set up time. Track comes with two racing surfaces, smooth for loose racing or textured for high level grip when using soft rubber tire compounds.
Features:
~ 12” X 12” tile size.
~ US patented design
~ Custom interlocking tiles for quick set up, tear down and storage.
~ Modular design that allows you to combine tracks and create many different layouts. NOTE: This track can only be combined with other 12” size RCP track tile kits or accessories.
~ Soft side rails that help protect the fragile plastic RC car bodies.
~ Quick set up with no tools or glue.
~ RCP Tracks are used by some of the top RC manufacturers exclusively for micro pro racing events around the world.
~ Flexible racing surface allows for the creation of bank turns, just like pro stock car tracks.
RCP Tracks Mini Expansion Kit
Part # 32436
The mini expansion kit by RCP is a great addition to the Mini 96 kit. Each expansion kit includes 24 straight tiles/rails + 36 blank tiles. The blank tiles allow you to widen the lane widths of your track in 12” increments. When adding blank tiles, your overall track layout will grow in length, so RCP Tracks includes 24 straight tiles and rails to make up the difference. The expansion kit includes 1 1/8” tall soft side rails and strong threaded attachment pins that secure the rails to the track. No need to worry about the rails coming off from car impacts. You can remove the rails after use or store them with the rails connected for faster set up time. Track comes with two racing surfaces, smooth for loose racing or textured for high level grip when using soft rubber tire compounds.
The adjacent picture shows a typical RCP Track layout utilizing the expansion kit. You can install the blank tiles at the corners for added room to make the turns or add them to the straights to make more room for passing.
Features:
RCP Tracks Mini Large Radius Inside Turn Kit
Part # 30145
RCP Tracks mini large radius turn kit is a great addition to layouts using the RCP Mini-96 or combinations kits. The kit includes all the pieces needed to replace the RCP short inside radius turns with large sweeping radius turns. A total of (4) complete layouts shown in adjacent picture are included in each RCP 30145 kit. Kit includes 1 1/8” tall soft side rails and strong threaded attachment pins that secure the rails to the track. No need to worry about the rails coming off from car impacts. You can remove the rails after use or store them with the rails connected for faster set up time. Track comes with two racing surfaces, smooth for loose racing or textured for high level grip when using soft rubber tire compounds.
Features:
~ Larger radius inside curves for smoother entry into the turns.
RCP Tracks Mini Long 45 Kit
Part # 30245
RCP Tracks mini long 45 kit is a great addition to layouts using the RCP Mini-96 or combinations kits. A total of (2) complete layouts shown in adjacent picture are included in each RCP 30245 kit. Kit includes 1 1/8” tall soft side rails and strong threaded attachment pins that secure the rails to the track. No need to worry about the rails coming off from car impacts. You can remove the rails after use or store them with the rails connected for faster set up time. Track comes with two racing surfaces, smooth for loose racing or textured for high level grip when using soft rubber tire compounds.
Features:
RCP Tracks Mini Chicane
Part # 30345
RCP Tracks mini chicane kit is a great addition to layouts using the RCP Mini-96 or combinations kits. A total of (2) complete layouts shown in adjacent picture are included in each RCP 30345 kit. Kit includes 1 1/8” tall soft side rails and strong threaded attachment pins that secure the rails to the track. No need to worry about the rails coming off from car impacts. You can remove the rails after use or store them with the rails connected for faster set up time. Track comes with two racing surfaces, smooth for loose racing or textured for high level grip when using soft rubber tire compounds.
Features:
Old 05-07-2009, 07:51 PM
arch2b's Avatar
30cm Tracks-Continued
RCP Tracks 3 Piece Finish Line
Part # C330XF
RCP 3 piece finish line tiles are a great addition to the Mini-96 kit when using the RCP 32436 expansion kit. This 3 piece tile kit comes with all the pieces needed to extend the finish line print across all three tiles. The finish line is printed across all three tiles. Kit includes two side straight tiles and one blank tile with a finish line print on both sides.
Features:
RCP Tracks Blank Mini Tiles
Part # 30020
RCP blank mini tiles are a great addition to your current track if you are looking to increase the lane width. Each tile measures 12” X 12” and comes with interlocking links on all four sides. Install them at the curves to allow more room in the turns or widen a large straight section to allow more room to pass. Tiles come with two racing surfaces, smooth for loose racing or textured for high level grip when using soft rubber tire compounds. Each 30020 kit comes with a quantity of 30 blank RCP tiles.
Features:
RCP Tracks Rail Liners
Part # P-1000
RCP rail liners are a great addition to your current track. Not only do they help protect the surface of the inside rails, they also help your car slide off the barrier in competition environments. You can install them on turns or add them to straight rails that receive most of the impacts. There are 5 liners per kit. Each liner measures 40" long and 1 1/8" tall. They come perforated in two spots that allow you to bend up the liners at the front and back of the rail with ease. The liners were designed with two perforations per liner to help lock in the rail and prevent them from coming off. NOTE: You will need to cut the liners at various locations to allow space for the rail pins. Also, some material needs to be cut away at the turns to allow for a smoother bend around the track rails.
Features:
~ Manufactured in plastic to allow flexibility around turns and corner rails.
~ Plastic construction that helps cars bank and slide off rails when impacted
~ Rear vertical support to hold the liner tight to the RCP foam rails.
~ Perforated for ease of installation.
Old 05-08-2009, 06:03 AM
arch2b's Avatar
dNaNo Race Tracks
dNaNo Race Tracks
Purchasing information and details on our new tracks for the Kyosho Dnano and other small scale RC's, Coming Soon.
  #4
Old 05-08-2009, 06:04 AM
arch2b's Avatar
RCP Track Details and Tips
Coming Soon Track Specifications, Tips and other useful information about RCP Tracks products.
Closed Thread
