Old 05-03-2009, 10:16 PM
martymoose martymoose is offline
Pairing with a non kyosho transmitter
Hi Guys,
I was wondering whether it is possible to use a different transmitter with the Dnano. I have a futaba 3pk with the 2.4 GHZ FAAST module and I am wondering whether this will work with the Dnano?? I am looking to buy a complete Dnano set but maybe I don't need to.
Any thoughts???
Martin
Old 05-03-2009, 10:27 PM
-J-'s Avatar
-J- -J- is offline
Send a message via AIM to -J- Send a message via MSN to -J- Send a message via Yahoo to -J-
If you have a Futaba 3PK, you can buy the KO PROPO ASF Mini-Z module, and the PN adapter, and use it with your dNaNo, but you can't use a FASST module with the dNaNo.
I'll see if I can't find links. Give me a minute.
Old 05-03-2009, 10:41 PM
At $80 the module is not cheap.
Old 05-03-2009, 11:18 PM
-J-'s Avatar
-J- -J- is offline
True, but to me it's worth it as I don't need another transmitter laying around the house, and being able to use my KO PROPO EX-1 UR is a also big plus.
Old 05-04-2009, 07:18 PM
MrNanoTrax's Avatar
i want the module for personal use... most of our customers will be new buyers so i don't see a need to 'stock' it yet. the only real need for it in my opinion is when u plan on using several models with one radio
Old 05-04-2009, 09:18 PM
I was really hoping that the 3pk with the 2.4ghz FAAST module will just work. Having to change modules for each model defeats the purpose. Getting the kyosho transmitter does not cost much more than a module for the 3pk. I might just keep it simple and stick with kyosho :-)
Cheers
Old 05-05-2009, 12:38 AM
-J-'s Avatar
-J- -J- is offline
Switching modules doesn't take hardly any time, plus you'll have much more adjustability at your disposal with your 3PK. The KT-18 works fine, but why spend more money for KT-18 when you can have more adjustability, in the module, for less?
Old 05-05-2009, 11:13 AM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
why spend $80 for the kt-18 when you can get the module necessary? would you rather carry two transmitters than take 4 seconds to change the module? wouldn't the added features of the higher quality tx also be a big selling point?
i don't know too many people happy with the kt-18. the early models with the mini-z were rife with quality issues that effected performance. i'm assuming since we do not see the same complaints here that they have corrected the problems since then.
Old 05-05-2009, 10:32 PM
MrNanoTrax's Avatar
nothing wrong with the kt-18... only issue is it doesn't support saved settings for different models. again, that would be my only point for using the KO module. if i DO get the KO module, then i'll used my Airtronics M11... that would be hot!
