05-02-2009, 10:47 PM
TinyRC & Mini-zRacer Fan
Fitting Parts Set
Fitting Parts Set
No. DNP301
Fitting Parts Set
No. DNP302
Fitting Parts Set
No. DNP303
Fitting Parts Set
No. DNP304
Fitting Parts Set
No. DNP401
Fitting Parts Set
No. DNP402
Fitting parts Set
No. DNP403
Fitting Parts Set
No. DNP404
Fitting Parts Set
No. DNP501
Fitting Parts Set
No. DNP502
Fitting Parts Set
No. DNP503
Fitting Parts Set
No. DNP505
Fitting Parts Set
No. DNP507
Fitting Parts Set
No. DNP601
Fitting Parts Set
No. DNP602
Fitting Parts Set
No. DNP603
Front Suspension Plate Set
Steering Upper Plate
Steering Lower Plat
No. DN013-01
Steering Lower Plat
No. DN013-02
Steering Lower Plat
No. DN-013-03
Front Suspension Plate Set (4U+4L)
Steering Lower Plate
No. DN013-04
No. DN013-05
No. DN013-06
No. DN013-07
No. DN013-08
05-02-2009, 10:48 PM
Front Knuckle Arm
Front Knuckle Arm (A/L+R)
Front Knuckle Arm
No. DN009
Front Knuckle Arm
Front Knuckle Arm
No. DN010
Front Spacer Set
Front Spacer Set
Upper Plate Spacer
Lower Plate Spacer
No. DN011
Tie Rod
Tie Rod
No. DN015-A244
Tie Rod (B/25.4)
Tie Rod
No. DN015-B254
Tie Rod
No. DN015-C264
Tie Rod
No. DN015-D274
Tie Rod
No. DN015-E284
Tie Rod
No. DN015-F294
05-02-2009, 10:49 PM
Motor Case
Motor Case (mm)
Motor Case
DN002
Motor Case ()
DN003
Motor Case ()
DN004
Motor Case ()
DN005
http://mini-zracer.com/mini-zgallery...YO-DN005-a.jpg
Rear Wheel Hub
Rear Wheel Hub
Rear Wheel Hub L
Rear Wheel Hub R
No. DN014-01
Rear Wheel Hub
Rear Wheel Hub L
Rear Wheel Hub R
No. DN014-02
Rear Wheel Hub (3L+R)
Rear Wheel Hub L
Rear Wheel Hub R
No. DN014-03
Rear Wheel Hub
Rear Wheel Hub L
Rear Wheel Hub R
No. DN014-04
Rear Wheel Hub
Rear Wheel Hub L
Rear Wheel Hub R
No. DN014-05
Rear Wheel Hub
Rear Wheel Hub L
Rear Wheel Hub R
No. DN014-06
Rear Wheel Hub
Rear Wheel Hub L
Rear Wheel Hub R
No. DN014-07
Rear Wheel Hub
Rear Wheel Hub L
Rear Wheel Hub R
No. DN014-08
Rear Wheel Hub
Rear Wheel Hub L
Rear Wheel Hub R
No. DN014-09
Front Wheel Set
Wheel Set (20/Front/Silver/2pcs)
Front Wheel
No. DNH001S-20F
05-02-2009, 10:51 PM
Front Wheel Set-Continued
Wheel Set
Front Wheel
Rear Wheel Set
Wheel Set (20/Rear/Silver/2pcs)
Rear Wheel
No. DNH001S-20R
Rear Wheel Set-Continued
Wheel Set
Rear Wheel
05-02-2009, 10:52 PM
Front Slick Tire
Slick Tire (FA/#50/2pcs)
Front Tire
No. DNT002-50
05-02-2009, 10:53 PM
Rear Slick Tire
Slick Tire (RA/#10/2pcs)
Rear Tire
No. DNT003-10
Body Mount Set
Body Mount Set (Nissan GT-R)
Front Body Mount
Wheel Base Adjust Plate
No. DNM303
Front Body Mount
No. DNM401
Front Body Mount
No. DNM402
Front Body Mount
No. DNM403
Front Body Mount
No. DNM404
Front Body Mount
No. DNM501
Front Body Mount
No. DNM502
Front Body Mount
No. DNM503
Front Body Mount
No. DNM505
Front Body Mount
No. DNM507
Front Body Mount
No. DNM601
Front Body Mount
No. DNM602
Front Body Mount
No. DNM603
