Old 03-25-2009, 11:50 PM
edhchoe edhchoe is offline
Atomic ball diff for Mini Z f1
Well, I swapped out the gear diff for the atomic ball diff. The car is making horrifying noise with the 6t pinion. I checked how the gears were meshing and they don't seem right at all. I put on the 7t pinion and they mesh better but the distance between them is too snug. I tried on the #2 motor guards and the gears sit too far and it is worse than when I had 6t pinion on with #1 motor guard.
What is everybody doing? It can't be just my car that's having this kind of problem with the aftermarket Ball diff.
Do I need Atomic pinion as well??
dNano - Silver Carrera GT (04/09) => White Enzo (son's)
dNano - Murcielago Yellow (04/09)=> Green (mine)
dNano - Enzo Ferrari Red (04/10, daughter's)
dNano - Corvette (04/10).
Old 03-26-2009, 01:21 AM
Well... The 8t pinion works. But it is a big jump from 45t/6t to 46t/8t. That is from 7.5 to 5.75. For my small track, I really wanted to use the 6t pinion... The batteries last longer and I can come out of a turn a lot faster.. etc.. Hmmm...
Old 04-05-2009, 03:49 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Ed, what pinons are you using, stock? I don't have my F1 in front of me right now, but, IIRC the Kyosho pinions are almost square w/ a slight round - maybe try some of these PN Pinions, they'll likely give you a much nicer mesh.
