Go Back   TinyRC.com > 1/43 and Smaller > Kyosho dNaNo > Kyosho dNaNo Gallery
Old 10-03-2008, 08:35 AM
fovea3d's Avatar
fovea3d fovea3d is offline
Toyota Supra custom body
This is an Epoch spec1 body that I had left. This will be for racing so I can preserve the beautiful Murcielago body.
Old 10-04-2008, 11:19 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Very cool A - can you show some pics of the modifications needed to convert from Epoch to dNaNo mount? Thanks!
Old 10-05-2008, 05:13 AM
fovea3d's Avatar
Well that was a 10mn job done before a race so not esp. fancy looking but it works
Front I ca glued some foam block cut in shape with a slit for the front mount.
For the side mount they are just screws that go through the body with some cable insulation to give some thickness to the screws reproducing the Dnano pegs. I could use plastic tubing but I could not find some in the correct diameter.
Don't mind the shaving under the hood, that was an attempt to lower the body when it was in use with the Epoch chassis.
I later removed the foam side rails you can see on the above pics. The purpose was to protect the chassis from side shocks.
Old 10-05-2008, 01:36 PM
tinyrc's Avatar
Very cool, thanks A!
Old 10-18-2009, 06:53 PM
Marcro Marcro is offline
The sides are exactly what I had planned for my Honda Z. Thank's! Not sure what to do for the front though yet as it's a completely different front end than yours. There really isn't much of a front on the Honda Z yet.
Good thing's come in small packages!
Old 10-19-2009, 12:54 AM
quarterpound quarterpound is offline
A different body mount set might give you a shorter front tab if you need it. When I get home I can get around to finally measuring mine and give you an idea.
FS: XMod - Custom black Supra, nearly every hop-up RC 2NR For Sale/Trade 3 07-18-2004 09:16 PM
Custom Fast and Furious Widebody Targa Top Twin 9V Supra! sagelwwa XMODS Mods and Projects 7 01-20-2004 11:34 PM
Custom body mounting tips micro kid XMODS Mods and Projects 0 12-31-2003 01:43 AM
Supra body starts car??? DraKhen99 Bit Char-G / MicroSizers 8 11-14-2002 09:11 PM
Supra (Racing) Body Set came in..how do I put it to gether ? HELP :) DJ_Mo Bit Char-G Parts and Hop-Ups 7 10-25-2002 08:30 PM
