Old 10-23-2002, 01:14 PM
catman25 catman25 is offline
can we have a def. answer..best mod that keeps reverse??
without reverse they are quick .with reverse they suck (for speed anyways).there must be a way to make then quick with out switching boards or adding another battery ..so many threads..i was wondering if we have a deciding answer ? thanks.
Old 10-23-2002, 03:58 PM
lnx_author's Avatar
lnx_author lnx_author is offline
Join the GNU Generation!
i can't really say whether or not the zz is fast(er) or slow(er) than other mini-rc cars, as i only own the zz line...
but i think your question is relative:
- some folks like touring control and Le-Mans type racing (or just pulling loops on a large floor)
- other folks like drag racing the cars
many of the mods seem aimed at achieving that perfect balance of speed and control, but honestly, there's only so much you can do for such little, lightweight cars?
i find my zz cars to be more than speedy enough, but then that's perhaps i derive more fun from the ability to accurately manuever the cars...
of course, it would be great to see the no-reverse mod enabled/disabled using a mobo pin switch - want control and reverse? set the switch one way... want lots of speed but no reverse? set the switch another way...
i'm looking for a mini-DIP switch to insert into a cut hole in the bottom of the carriage... this could be use to control lighting, charging, speed, battery use, etc., as there are typically 4-8 switches in a DIP...
just my $0.02...
ZZ No Reverse Mod How to? Mr. Fisherman ZipZaps 18 04-17-2003 09:02 AM
A stupid question: Switched Reverse mod wire colors = ? frizzen Bit Char-G Mods and Projects 0 01-12-2003 10:37 PM
NEW CONTROLLER MOD! Check it out.... mike_diaz19 Bit Char-G / MicroSizers 13 12-19-2002 12:02 AM
Reverse mod..while keeping reverse ZIZI ZipZaps 4 11-26-2002 05:06 PM
No reverse mod Colt45101st Bit Char-G / MicroSizers 3 11-24-2002 07:04 PM
