Go Back   TinyRC.com > 1/36 and Smaller > Losi Micro-T / Desert Truck / HIGH Roller > Micro-T General
Old 02-04-2008, 10:23 AM
NinJato's Avatar
NinJato NinJato is offline
Steering Link Fix
I kept breaking the steering links. I also noticed that thread-lock "eats" the links. I made my own from tiny zip-ties and now they don't break.
The down side is that if you push on the front end, the suspension is a bit stiffer (even with the screws a little loose). But, now when it hits bumps, the front end seems to absorb the hit better and stays on the ground.
I have a friend that is going to try "feeler gauge" (very thin metal).
Has anyone found something that works better?
Gene Police: "Hey you! Get out of the Pool!"
Old 02-06-2008, 02:31 AM
NinjaMaster NinjaMaster is offline
Lexan is your friend, you can get a lexan wing for a buggy or stadium truck from your LHS pretty cheap, and make tons of them, just score with a knife, and when you flex, it will break clean and make perfect lines.
Steering fix that works TypeZer0 XMODS 16 01-07-2005 02:31 PM
Steering Range Fix: Mod the Tierod ikinari XMODS 28 03-31-2004 11:50 AM
Copper wiresfor steering? FIX!! Web Guy Bit Char-G / MicroSizers 3 03-14-2003 10:20 PM
How to fix bent steering spring? VERTiG0 Bit Char-G Mods and Projects 2 12-12-2002 10:14 PM
