Go Back   TinyRC.com > 1/36 and Smaller > Losi Micro-T / Desert Truck / HIGH Roller > Micro-T General
Old 09-20-2007, 08:05 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
Losi 1/36 Micro-Desert Truck
http://teamlosi.com/Products/Default...rodID=LOSB0233
1/36 Micro-Desert Truck RTR(LOSB0233)
From the desert sand to the palm of your hand!
Complete RTR, everything included
Extended chassis for increased stability and scale looks
Fully independent suspension with friction dampers
Differential-equipped transmission with adjustable slipper
Powerful micro-motor for quick acceleration and impressive top speed
Digital proportional electronic speed control with reverse
Losi 27MHz AM radio system included
Micro-Desert Grip tires mounted on chrome Micro bead lock-style wheels
Portable charger included (powered by included alkaline batteries)
Ni-MH battery pack installed
Includes 8 AA alkaline batteries for charger
Includes 8 AA heavy-duty batteries for transmitter
Designed with the same award-winning features as the Micro-T™, the Micro-Desert Truck™ offers desert racing style in a micro truck that’s just under 6 inches long (about an inch longer than the Micro-T). Packed with a Ni-MH battery, independent suspension, differential-equipped transmission and 27MHz Losi AM radio system, the Micro-Desert Truck has the speed and handling to tackle nearly everything you can throw at it. Take it with you anywhere you go and satisfy your RC cravings with the Micro-Desert Truck.
Product Specifications
Type: 2WD Desert Truck RTR
Scale: 1/36
Length: 5.7 in (114mm)
Width: 3.5 in (89mm)
Wheelbase: 3.5 in (89mm)
Weight: 4.0 oz (112g)
Chassis: Extended composite tub
Suspension: Independent
Drive Train: 3-gear transmission w gear diff and slipper
Tire Type: Micro-Desert Grip tires mounted on black micro bead lock-style wheels
Motor or Engine: Micro electric
Speed Control: Electronic, fully proportional forward/reverse
Radio: Losi 27MHz AM pistol
Servos: Sub-micro
Batteries: 4.8V 150mAh NiMH (included)
Charger: Peak (included)
Wheel Size: 0.75 in (19mm) diameter
Kit/RTR: RTR
Shock Type: Coil-over friction dampers
Body: Factory-decorated Desert Truck
Ball Bearings: BB equipped transmission
arch2b's Avatar
all iamges from losi
Old 11-11-2007, 07:18 PM
GiantScale GiantScale is offline
Send a message via AIM to GiantScale
I just picked up a few. My only complaint is the run time. And that I cant find a >400 mah lipo to fit the larger 34 x 34 x 10mm compartment. I guess I will have to settle with the stock sized 150-220 mah lipo's
Im trying to find a shop who has all the micro-t hopups I need.
stranded in iowa
losi micro t losimicrot Micro-T General 11 06-05-2007 01:27 AM
Kidriffic Micro RC 4x4 Monster Truck Dissection (pics) actofgod Other Tiny RCs 90 02-03-2005 07:32 AM
How to Build a 1/87 Scale RC truck a.k.a.TTTT Overlander TTTT 445 02-25-2004 07:15 PM
How big are the micro machines monster truck tires? Ovgron Bit Char-G Parts and Hop-Ups 0 06-18-2003 04:09 PM
