Go Back   TinyRC.com > 1/36 and Smaller > Losi Micro-T / Desert Truck / HIGH Roller > Micro-T General
Old 05-10-2007, 10:06 AM
nazcom_101's Avatar
nazcom_101 nazcom_101 is offline
My Custom - Micro T + Case + Ramps
The Case:
As u all know, micro T's don't come with a case to keep them in when your not using them or when u are taking them out with u... so I though I would make my own... and here it is...
I made a mesh tray, which I painted black to sit the batteries on while they charge... I also added a 40x40mm PC, powered via a 9v PP9 battery, which will kool the motor down between runs...
The Micro T :
now for the micro T side of things... my current spec is:
- Atomicmods bb motor
- ball bearings
- alloy shock set
- alloy front skid plate
- threaded steel Wheel shaft shafts
and of cause, the custom hard plastic body, which as u can see I am still working on... lol...
the body I got from a 1/32 nissan king cab - Tamiya kit... which I have had to cut the rear cab out of to make the body lenght shorter to fit the micro T's wheel base...
The Ramps:
Here is a pic of my frist 2 ramps I made from cereal boxes...
I will get some vidz made, once my new servo gets here from the USA, probs next week...
I will also update, again once I have more work done on the body and my new rims set on it...
Old 05-11-2007, 12:00 AM
TheMechanic
Looks great, did you make the wood case?
Old 05-25-2007, 09:26 AM
nazcom_101's Avatar
no... it was an old art box, which I made new spacers for...
updates added a better longer aerial, along with the new rims and another body, which I will use along with the custom one, once I get it finished... lol...
I also made some spacers to stop the adjustable o-ring slipping back up to the top, on the HR shocks... I kut up some spare tubing from RC aerial to make the spacers with...
after seeing a tut Suzuki did using some plastic tubing from wire end connectors...
Below is a black widow spider design I did, which I will print onto some decal paper for the sides of the above body...
Old 06-30-2007, 10:23 AM
nazcom_101's Avatar
update time: I have a clear baja body that I still need to kut and mount, will get a photo of that up soon...
but what I do have is new photos of my micro t's chassis...
I also made some new jumps/ramps... I made 2 of the one u can see my micro t on in the below photos...
New Specs/ Parts list for the above micro t :
- Ball bearings
- HR Alloy shock set (Blue Springs)
- HR Alloy front skid plate
- Threaded steel Wheel shafts
- GPM Alloy Camber Links
- GPM Alloy Rear Arms
- HR Alloy Front Arms
- HR Alloy Silver Ovals Rims 0ff/set
- HR Front shock damper tower
- GPM Rear shock damper tower
- HR Losi Micro T Silver/blue Aluminum main chassis
I am wroking on a newer smaller aluminum case, along with a new video, so I will update again soon...
Old 06-30-2007, 10:43 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
That is one dead-sexy T !!
Very nice.
Old 07-01-2007, 10:11 AM
nazcom_101's Avatar
thanks!
Old 08-11-2007, 10:20 AM
nazcom_101's Avatar
Here is a few pics of my micro t with its new wheels, which are made by Technical Racing Products, I found my set on ebay spain...
Old 08-12-2007, 04:25 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
damn, thats a nice looking micro-t! if you don't mind me asking, how much performance gets sapped by all the aluminum weight?
Old 11-30-2007, 05:56 AM
nazcom_101's Avatar
Not sure... but the bit extra weight of the aluminum keeps the fast thing on ground more so it probs has better steering than it did before... lol...
New Update: I got a atomic type 1 body and painted it with some Custom Colour - Sapphire Fusion spray paint, which I backed with some Custom Colour - Jet black...
I made a small video, to show the colour change from different views/ lights...
Body Photos:
Chassis Photos:
The only thing I still need to get for the chassis is a alloy gear box and laterz on a BL set-up...
New Custom micro bodies mitsu_kidd Micro-T Parts and Hop-Ups 9 05-29-2011 04:44 AM
custom case and custom f-150 in making lancer11 ZipZaps Mods and Projects 6 09-06-2004 06:52 PM
new custom on micro site 4-D Combat Digi Q 1 02-12-2004 06:49 PM
MY Custom Micro RC Story JadeFoxx Bit Char-G / MicroSizers 5 12-28-2002 10:57 PM
Need advice on custom micro D.S.I. Other Tiny RCs 2 10-27-2002 06:07 PM
