Old 04-22-2007, 04:28 PM
ownsdaily ownsdaily is offline
steering?
I was wondering how would i put in a different moter for steering? if anyone could show pictures or anything like that it would helo alot.
Old 04-23-2007, 01:15 PM
Michael.mt2k's Avatar
Michael.mt2k Michael.mt2k is offline
Another old modder.
Check out any of the mods in this section.
Steering motor replacement is pretty self-explanatory.
1) remove PCB cover
2) pull out original motor carefully by the wires
3) remove gear from original motor
4) cut wires to original motor
5) install gear on new motor
6) solder wires onto new motor
7) install new motor and test
8) If steering is reversed, reverse wire connections to the new steering motor
9) if new motor is longer than the original, make a hole in the PCB cover to accommodate it.
10) re-install PCB cover
11) Profit! (just kidding) you should be done now.
If you need more detailed instructions on the particulars of this process or the terms used it might be a good idea to Google for tutorials on the subjects or practice soldering etc on something else first.
Old 08-06-2007, 07:12 PM
fatman's Avatar
fatman fatman is offline
good
i tested i good work
if its not broke i can fix it
Ideas on how to increase steering power mde Bit Char-G / MicroSizers 4 05-01-2004 03:42 PM
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 01:16 PM
Steering Help ZipRC ZipZaps SE 1 09-21-2003 10:57 AM
