Old 11-13-2006, 08:23 AM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
turning spring
I just lost the turning spring. Where can I get a new one?
BAE
Smaller models, more control
Old 11-13-2006, 04:51 PM
Jazz32
I'm not sure where you can get a new one. I have seen people take a spring out of a pen and adapt it to work. If you cut one of those springs and straighten out some of the sections it might work. I'm not sure otherwise, but you should be able to come up with a substitute.
Old 11-13-2006, 08:50 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
Long time back I heard about someone modifying a spring out of a VHS tape. If you've got one sitting around that you don't care about, might be worth taking it apart for the spring.
Snake Mod Snake Mod is offline
Send a message via MSN to Snake Mod
I had the same prob and i found a small wire with 8 aluminum smaller wires inside. Well the smaller wires were hard to bend so i made one fit just to size (it wasn't one of those thick wires). But yeah I guess find aluminum wire the same thickness as the spring and bend and straighten to fit. Hope This Helps
MOTORWORKS
[color=green]
Old 11-14-2006, 06:22 AM
I'll try the VHS return spring. Thanks. BAE
Old 03-02-2007, 07:12 PM
GrimChild GrimChild is offline
Send a message via Yahoo to GrimChild
Guitar strings make great micro springs, whether you use them straight, or coil them. the thicker(wound) strings work great for a straight perfectly bendable micro spring. If you decide to wind your own, use a medium guage wire(Not wound) and coil it around any object smaller in diameter. applying a little heat also helps just don't let it turn red hot to the point where the wire gets deformed.
This is probally the only original idea i've had and thought i'd share
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 02:32 AM
steering spring xt600 ZipZaps 8 03-06-2004 10:58 AM
Non front wheel turning or front wheel turning? bvsciguy Digi Q 0 09-13-2003 11:05 AM
TURNING spring trinitron2k2 Bit Char-G Mods and Projects 2 03-02-2003 09:36 PM
Stiffer Steering Spring dcp ZipZaps 5 11-27-2002 10:18 AM
