Old 11-10-2006, 02:49 PM
rody rody is offline
Drifting an Xmod
I been trying to do some research on how to drift an Xmod, because it looks fun. Bear in mind I'm new to both R/C's and drifting. Most of the drift mods seem to have the following in common:
Stage 2 motor
Drift tires, or taped tires
AWD
hard springs front suspension, soft springs rear
Lithium batteries
One question I had on this, on real cars most drift cars are rwd, why do people recommend awd on Xmods? Wouldn't the same principles of drifting apply to an r/c car, and a real car? If not, are there different techniques to drifting an Xmod?
The one I've been experimenting with is to go into a corner fast, let off on the throttle, until at the apex of the turn, and hit full throttle again. So far, it hasn't worked, but I'm just running a stock Xmod, and my technique probably sucks. Anyone have any pointers? Thanks for your help.
Old 01-01-2007, 09:25 PM
anticasper86 anticasper86 is offline
Send a message via AIM to anticasper86
Stage 2 motor
AWD
Lithium batteries
well, an xmod needs awd because they don't have the horsepower and rpm's to hold through a whole turn. If you wanna drift, i need to learn your setup.
SCION
4WD
yellow suspension front axle
blue suspension rear axle
drift tires
decals kit
stage 2 motor 9-25
reachargable rs batteries
NSX
rs rechargables
stage two white
body kit
foam tire
CIVIC
rs rechargables
AWD
body kit
metal bearing
stage two red
yellow front/ back suspension
tie rods
Drifting explained steelo Miscellaneous Discussion 5 07-14-2007 07:35 AM
A simple guide to drifting (WIP) micro-rc-guy XMODS 0 02-06-2007 04:20 AM
Xmod Evo Truck HD Dogbone Mod CinnaBun XMODS Mods and Projects 0 02-03-2006 10:07 PM
My XMOD Drifting Tbird Man XMODS 5 02-09-2005 06:36 PM
