Old 10-21-2002, 12:18 PM
lnx_author's Avatar
lnx_author lnx_author is offline
Join the GNU Generation!
Simple Lap Counter w/PICS
- as promised, here are pics of a simple lap counter that can cost as little as $9 or less...
- the first step is to get an LCD counter... radio shack used to offer one for $14 or so, but dropped it from its catalog... fortunately, there are alternatives!
- an inexpensive step pedodemter! one of the benefits of using a pedometer is that you can get 'em cheap, but if you want advanced features, such as backlighting, a clock, timer, and so on, you can!
- these counters are available nearly anywhere: Target, Sports Authority, D.I.C.K.'s Sporting Goods, etc.... interestingly enough, i couldn't find any at Wally World's on-line store (Wal-mart), but i'm sure they're carried in the stores?
- my primary consideration was using a step counter, not a distance calculating step counter... step counters are used to well, count steps, but in our case here, to count laps!
- here's the next higher-end counter you could use (about $5 more than the one in this project):
Old 10-21-2002, 12:20 PM
lnx_author's Avatar
crack the back of the pedometer, and you'll see where to solder your switch wire... i inserted a twisted pair of thin wire, drilled a hole through the back case, knotted it, then soldered on the connections...
don't take the front part of the pedometer apart, as the LED is held in place by the tiny PCB's screws - no soldering!
i then drilled a hole in the flip-open part, and bolted the unit onto a piece of plexi:
Old 10-21-2002, 12:26 PM
lnx_author's Avatar
here's what the unit looks like from the front (this is the pedometer i used, which is cheaper)... note that i cut out art from zz wrapping!... you can also see the reset counter... more expensive units will have a clock, backlighting, different modes, timers, and so on... this one was $9+tax:
Old 10-21-2002, 12:27 PM
lnx_author's Avatar
here's the lap counter, which is mounted on a simple plexi stand... note switch wires trailing off to the left:
Old 10-21-2002, 12:30 PM
lnx_author's Avatar
here's the lap switch... kind of a brain-dead approach, but one anyone can build and which costs... NOTHING! ... you can make the switch as wide or thin as you want... the secret is to make it thin enough so it doesn't impede your zz machine's progress as it screams across the track:
Old 10-21-2002, 12:34 PM
lnx_author's Avatar
finally, here's the switch... foil inside the folding paper, plastic, etc., with the wires taped inside...
as the car runs over, the foil makes contact and increases the counter... you can use this approach to build a second counter on the other side of your track...
i know this is a simple approach, and not as sophisticated as Steve's IrLED/laser pointer, but it works!
HAVE FUN!!!
and let's see some more lap counters!!!
i'd prefer an inexpensive, battery-driven Ir switch - let's see a design that's cheap and uses a Lithium battery!
thanks to all on the forum here, and all the great ideas and mods on playing with these great little cars!
Old 10-21-2002, 01:51 PM
DesertJedi's Avatar
DesertJedi DesertJedi is offline
What ever you say Granpa?
BRILLIANT!!!!!
Old 10-21-2002, 04:31 PM
marc515192's Avatar
marc515192 marc515192 is offline
ZipZap Maniac
Send a message via Yahoo to marc515192
I likE it
1999 Super Modified Zinc Yellow SVT Mustang ZZ
Bit PCB MOD
It's a sleeper! hehehehe
M/S Mitsubishi EVO Lancer w/modified clone motor
M/S Nissan Skyline
M/S Honda S2000
Old 10-21-2002, 04:50 PM
john john is offline
Too Many Hobbies
Very nice idea! I hadn't thought of a step counter. I was trying to figure out a way to use the magnet in the car's steering and a bicycle computer. I'm still considering it, but it's not very sensitive, and I'm not skilled enough to tweak the sensor. Maybe someone here is.
Anyway, I thought I'd throw out an alternative to the step counter... well actually, it is essentially a step counter... but this one you have to build yourself.
http://mpja.com/product.asp?product=6001+KT
If you go to mpja.com and hit one of the links for kits you'll find everything from amplifiers to light-up, flashing LED arrows, to IR sensors and such.
A few kits from this site, and little innovation, and you could have yourself a custom IR lap counter and probably spend under $30. It's a neat electrical parts website all the same, even though it's a nightmare to navigate.
microrc banned me for mentioning this forum.
Old 10-21-2002, 07:04 PM
DesertJedi's Avatar
OK, let's review quick and dirty $9
Build it yourself out of parts $30
Doing the math...priceless!
That's one of the things that makes this brilliant!
Old 10-21-2002, 08:22 PM
lnx_author's Avatar
well, there's something to be said for building kits/projects from scratch - for one, you do learn quite a bit about different components... (btw, there was some cool stuff on the mpja.com site too!)
i'll bet that some folks in this forum are working right now on some more cool zz stuff - this is why i like hanging here! you never know what you're going to find, and other people can give you great ideas...
my problem is that i'm lazy, and unless really, really, really motivated, don't have the energy or patience for a scavenger hunt for parts...
now if there was an [relatively] inexpensive, easy to use, and battery-driven lap counter made for the zz, i might pop for it... but i've set a mental monetary limit on what i'm going to spend on zz stuff...
back onto the mods! let's see some more stuff, folks!
Old 10-21-2002, 09:37 PM
Steve's Avatar
Steve Steve is offline
zipped up tight!
I LIKE IT! Though you've just inspired me! The next mod you see from me will put this site on the map...er, well...it will be a good one I promise.
Old 10-21-2002, 11:07 PM
lnx_author's Avatar
that's great! i can hardly wait!
i was hoping to use a more intelligent switch (ya gotta admit that a fold of paper is braindead)... i was wondering about how to do a simple light emitter/collector to control a relay, which would be really cool, but didn't know the particulars about Ir transistors or the IrDA pair offered by Rat Shack... (i read about the distance limitation you mentioned in your counter/timer, and definitely like your switching approach a *lot* better)...
hope to see your project soon!
Old 10-21-2002, 11:56 PM
Steve's Avatar
zipped up tight!
The beauty of the paper switch is simplicity and price. Besides, now that you have a working prototype to base everything off of, you can make little improvements here and there.
The Phototransistor the Shack has is basically the same as your paper switch, except light triggers the closing of the switch instead of weight. Your setup would work great with a laser pointer LOL.
Old 10-22-2002, 08:16 PM
Steve's Avatar
zipped up tight!
Cheap $4.00 LCD thingy
Just finished my daily trek to the Shack and noticed they have a digital golf stroke counter that has buttons to count putts and regular strokes. I bet you could use this thing for the above counter idea. It's like $4.00 on clearance.
Radio Shack Xmod Lap Counter Dragon40 XMODS 9 02-15-2005 07:36 PM
RS Lap Counter? Remember this? Dragon40 XMODS 0 01-06-2005 05:10 PM
Digital Lap Counter - is it any good Vampyre Bit Char-G / MicroSizers 3 04-07-2003 06:53 PM
Lap Counter Project - DONE lnx_author ZipZaps 2 10-22-2002 11:11 PM
