Old 10-25-2006, 08:28 AM
dj_miracle dj_miracle is offline
AWD Diff blocks tie rod?!
HI guys ;-)
Yesterday I installed my Gen1 AWD Kit. Now my front Diff blocks my GPM tie rod, so i can steer left, but not to the right. The part of the tie rod where the servo plugs in hits the diff.
What can i do???
Greetz
Old 10-25-2006, 10:08 AM
rob3662 rob3662 is offline
You need to get a flat file and file down the front of the two prongs for the servo horn. If you make it so the front of the prongs look like the back of the prongs you should be Ok. Also you might need to file down the front of the tie rod where it passes under the bevel gear, I had to for mine. Hope this helps.
Old 10-26-2006, 04:01 AM
THX a lot
Now it works....
What's a Diff (Differential)?...Here's the answer Namuna XMODS Parts and Hop-Ups 3 07-02-2006 01:44 PM
xmod tie rod xxxmod XMODS Parts and Hop-Ups 9 03-01-2005 04:03 PM
what aluminum tie rod xxxmod XMODS Parts and Hop-Ups 2 02-28-2005 08:38 AM
gap between tie rod and servo horn jamgunner XMODS Mods and Projects 3 07-24-2004 03:53 PM
How does a tie rod work? bvsciguy XMODS 7 02-20-2004 11:36 AM
