Old 10-22-2006, 04:46 PM
supra street supra street is offline
chassis set ups
What is the best set up for drifting, spring stiffness, soft, medium, stiff. Tie rod degrees, 1.5, 3, 4.5.
Old 10-22-2006, 05:57 PM
keith92 keith92 is offline
well u want drift tires of some sort. soft in front and hard springs in back i believe. and a must is 4 wheel drive. 4.5 degrees would give u the smalest turning radius, i stick with 1.5 tho becuase it makes it easier to center the wheels and go straight if u want to get up some speed. some people lock there read differential, i never tried it tho and dont plan on it.the gearing should use the torque intesive. if u dont have a stage 2 upgrade the stock will do. droping the ride height helps also. theres alot about drifting on this forum look around and try a search.
for my car which i can drift quite well.i use a stage 2 with max torque gears drift tires 4 wheel drive, hard in back soft in front springs. and thats all i think anyone really needs.
Old 10-22-2006, 06:27 PM
thanks. i have drift tires, 4wheel drive, stage 2 drift motor with magnet upgrade, and suspension kit ( stiff shocks in the front and medium in the back).
Old 10-22-2006, 06:29 PM
that sould be fine. if i were u i would change the shocks around but it dosnt make that much of a difference. the rest is just practice.
Old 11-20-2006, 07:05 AM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
I find that stiffer shocks in front help my steering. They don't affect my drifting. However the dust and dirt on the floor do very much. You'll have that. ;(
Smaller models, more control
Old 11-23-2006, 07:24 PM
moddsmann moddsmann is offline
Send a message via AIM to moddsmann
lock the rear diff 4 a damn good drifter
if its fast flamable and deadily count me in
my cars infinity g35 and a hummer in the shop
Carpet Set ups FastRSX XMODS Mods and Projects 1 12-17-2003 10:03 PM
Carbon Fiber Chassis WillS Mini-X 22 08-13-2003 07:17 PM
trading mini rc parts, and hop ups for a 27 funtionally chassis ronak26 Bit Char-G / MicroSizers 1 01-25-2003 01:55 PM
Chassis Tweak! Pics! ModemJunki Dynamite Rocket Racer 5 01-13-2003 12:36 AM
Stock chassis warp Mr Freeze Bit Char-G / MicroSizers 0 12-05-2002 11:35 PM
