Old 09-17-2006, 02:08 PM
keith92 keith92 is offline
custom drifting tires?
is there any way to make rubber a little harder. i cant stand drifting tires and hard slicks are just a little too soft. so i was just wondering if there is any way to harden rubber a bit.
Old 03-11-2007, 11:34 AM
mustangracer mustangracer is offline
im not too sure if this is true but this guy tryed freezing his tires and he said it worked i dont kno though
My xmods/setup
1.mustang
4wd
drift kit
2.f150
lift kit
4wd
atomic motor
metal wheel nuts
logic lights
Old 04-03-2007, 09:38 PM
The Red Titan The Red Titan is offline
i heard in some other forum that you can wrap electrical tape around the tires like 3 times or sumthin. electrical tape is smooth and im guessin it works good. you can buy it just about anywhere
Old 04-03-2007, 10:45 PM
xmodcowboy2007 xmodcowboy2007 is offline
try any mini z shop, or TOPCAD for different style rubber....I found a set that are just fine for normal driven.
Old 04-04-2007, 03:58 AM
drewdown84's Avatar
drewdown84 drewdown84 is offline
Send a message via AIM to drewdown84 Send a message via Yahoo to drewdown84
ive used scotch tape... and electrical tape... they both work fine... scotch tape gives more of a drifting effect when you use it on the rear tires only... and electrical tape isnt as good as you'd think cuz the sides of it collect dirt because of all the adhesive most brands use...
...info if you wanted to take that route...
67' Pontiac Firebird -> 6 Cell, Bodykit, AWD, RS Bearings, 4.5 Tie Rod With Blue Front Springs And Yellow Rear, Stage 2 Motor With 9/25 Gearing, Modded Light Kit, Drift Tires...
H2 -> 6 Cell, RS Bearings, AWD, Lift, Body
05' Ford Mustang -> Custom Tamiya Paint, Light Kit and thats it cuz it aint a GM... gonna get a 6 cell when my girl learns to solder...
Traxxas T-Maxx .15 -> Aluminum chassis parts... soon to get a custom light kit...
Associated RC10GT -> RPM bulkheads...
Old 05-29-2007, 08:22 AM
sarniaboy sarniaboy is offline
Re: Drift tires
I've used a set of tires from a diecast model. Look around for vinyl tires from any model kit, Some work , some don't. Experiment my boy.
Old 06-04-2007, 12:25 PM
AxeMarauder AxeMarauder is offline
to get a good drift tire,I take the regular Xmods tires(preferably the ones without treads) and I put gloss clear coat model paint on them. This makes the tires slippery and it also gives 'em a tire wet black magic look.
Old 06-04-2007, 02:55 PM
streeturbo21 streeturbo21 is offline
Re: drift tires
i made mine with pvc pipes. works great. just have do grind down the middle ridge and glue it on.
Drifting explained steelo Miscellaneous Discussion 5 07-14-2007 07:35 AM
A simple guide to drifting (WIP) micro-rc-guy XMODS 0 02-06-2007 04:20 AM
Good ol' Charlie's tutorial on tricking out your Xmods Custom RC. charliebrown XMODS 17 12-19-2003 04:12 PM
custom tires // track joez2872 Bit Char-G / MicroSizers 2 02-21-2003 08:27 AM
custom tires // track joez2872 Bit Char-G / MicroSizers 1 02-21-2003 02:10 AM
