09-17-2006, 01:31 PM
Radio Shack Wheel (rim) upgrade
ok does the wheel up grade for the trucks also work on the cars. i really want a set of wheels with the black on them but i cant seem to find them for the cars. help please
XMODS:
Acura RSX
wild body kit, carbon fiber hood, and spoiler
4 wheel drive
blue stage 2 motor
Command Logic Lights
LOTS OF STICKERS!!
*FAVORITE OF ALL OF THEM*
Toyota 97' Supra
Red Stage 2 motor
4 wheel drive
Hummer H3 or 2 (i dont remember)
4 Wheel drive
Off Roading Kit
Infiniti G35
Stock other then Ground Effect Lights
09-17-2006, 01:41 PM
Hulk smash!
Nope, the Truck wheel upgrades are a considerably larger diameter (vs the car wheels). You'd have to trim out the wheel wells on the car to keep the wheels from rubbing.
09-17-2006, 01:47 PM
alright but is there anyway i can get the rims for the cars with the black on them
XMODS:
Acura RSX
4 wheel drive
blue stage 2 motor
LOTS OF STICKERS!!
Toyota 97' Supra
Red Stage 2 motor
4 wheel drive
4 Wheel drive
Off Roading Kit
Infiniti G35
09-17-2006, 01:59 PM
ok in one of the rim upgrade kits there is one like that but i dont know which one it is, look on ebay. there is also another idea which i did check it out. i bought some skyline rims off someone and then went over them with a couple coats of spay paint.
omg 100th post!
09-17-2006, 02:24 PM
If you have another set up hubcaps that you like the pattern on I can tell you how to remove the paint from them without damaging the plastic.
Things you'll need:
4 X-mods hubcaps of your choice
1 Zip-Lock bag
1 Can of Oven Cleaner
1 Paper Towel
1 Toothbrush
1 Small bowl
Optional things:
1 Spray can of glossy clear coat
1 or more jars of model paint
1 can of paint thinner
1 small paint brush
Fold your paper towel twice and soak it with the oven cleaner. Then place it in the zip-lock bag. Place your hubcaps on the paper towel, give one more long spray (2-3 seconds) of oven cleaner in the bag and seal. Let it sit for about an hour or two. Most of the paint should be removed from the hubcaps at this point, if there is any paint left on them here is how you remove the rest. The oven cleaner should have puddled up in the bag by this point. Take your hubcaps and paper towel out of the bag and place them to the side. Dump the excess oven cleaner into a small bowl. Dip your toothbrush in the bowl and scrub your hubcaps until the remaining paint has been removed. Rinse with warm water and let your hubcaps dry.
If you want your hubcaps to have accents use modeling paint. Thin it out with your paint thinner with a 50/50 mixture of paint and thinner and with your small paint brush add your accents and let it dry.
To give your hubcaps that nice painted rims look spray a light coat of glossy clear coat and let dry.
You can do this to any painted on plastic product to remove paint. Some tampo's may not come off with this method and can only be sanded off without damaging the plastic. Just make sure you are using really fine grit sand paper and wet sand the surface until the tampo is removed.
If you do this to a body that has lighting on it make sure you remove the electronic components before you do this.
This is a relatively cheap process. I hope this helps you out. If you do this don't forget to show us the results.
If you can't beat 'em buy more stuff!
09-17-2006, 04:10 PM
Things you'll need:
1 Zip-Lock bag
1 Paper Towel
1 Toothbrush
1 Small bowl
Optional things:
1 small paint brush
wow thanks i wasnt expecting such a big explanation actually i wasnt expecting an explanation at all. but this is amazing thank you so much for the info. just one question. do you have to remove the base paint in order to paint over it? thanks again for the help!!
XMODS:
Acura RSX
4 wheel drive
blue stage 2 motor
LOTS OF STICKERS!!
Toyota 97' Supra
Red Stage 2 motor
4 wheel drive
4 Wheel drive
Off Roading Kit
Infiniti G35
09-17-2006, 06:19 PM
Nope, just scuff them a little bit with some fine grit sand paper first to give the new paint something to grab onto, otherwise you may want to use a thin coat of primer first. Just remember when you paint it is better to do really thin coats and allow enough time for each time coat to dry before you start the next coat. Make sure you put one or two coats of clear coat on too that way you won't have to repaint them as often. If they get scuffed just wet sand them a little and if need be and another coat of clear coat.
09-17-2006, 09:32 PM
can i use them on my infiniti evo?
XMODS:
Acura RSX
4 wheel drive
blue stage 2 motor
LOTS OF STICKERS!!
Toyota 97' Supra
Red Stage 2 motor
4 wheel drive
4 Wheel drive
Off Roading Kit
Infiniti G35
09-17-2006, 10:09 PM
yeah, all the car tires are the same size.
09-18-2006, 10:05 PM
Naruto Champion
i did this
People come and go, but no one stops and looks.
Black/Red F150- Lift kit, body lift.
Black Camaro- 6th cell dragster with custom tires.
Blue Mustang-Slammed wheels
Black Hummer- Everything
09-18-2006, 10:15 PM
dude thats amazing. fif u paint those your self??!!
XMODS:
Acura RSX
4 wheel drive
blue stage 2 motor
LOTS OF STICKERS!!
Toyota 97' Supra
Red Stage 2 motor
4 wheel drive
4 Wheel drive
Off Roading Kit
Infiniti G35
09-19-2006, 05:08 PM
those are the truck rims
09-19-2006, 05:10 PM
do the wheels rub on the fender walls when the wheels are turned?
09-19-2006, 05:14 PM
will they fit good on the lancer...with body kit and everything cuz they would look hot on that
XMODS:
Acura RSX
4 wheel drive
blue stage 2 motor
LOTS OF STICKERS!!
Toyota 97' Supra
Red Stage 2 motor
4 wheel drive
4 Wheel drive
Off Roading Kit
Infiniti G35
