Old 10-20-2002, 09:49 PM
PhillyB PhillyB is offline
did the dual cell mod - a few questions from a newbie here
ok i got two 120mah 1/3 aaa batts from QFM to fit inside the chassis, lots of dremeling (you can see the sides of the batteries through the chassis just above the charger clip holding area (for lack of a better name) but they fit just fine - had some trouble with the wiring - got it working - my question is how do i tell if i fried a cell? i may have left the iron on the cell too long - it made a small hissing sound - i also did the charger mod so i get 3.0V from the remote - charge for 3-4 min and i get around 3-4 min of full speed runs - this is with a 3.8 pink motor and green (high speed) gears - oh this is a microsizer btw - how can i tell if i fried the cell - it seems to work ok - i just want more runtime from a 4 min charge
its like freaky fast, i have to use soft tires up front and stock in the rear - it spins from a start without steering - with stock front tires any touch of any direction sent the car rolling end over end - now i get picture perfect high speed drifts - its so fast its unbelievable - im thinkin of getting the dB body and poppin a third cell in there above the circuit board
this is awesome - all credit goes to this board too btw or tinyrc.com - i showed up some zip zaps - they didnt even want to race me after they saw that i spin the tires - this was with one nimh and a 3.8 in a very small room - they all want some now
Old 10-22-2002, 10:16 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Well, if the car is faster, then the cell sounds like it is working. If it was fried, it would kill or at least impair the circuit.
Old 10-22-2002, 10:56 PM
oh ok - yeah i think its good - i just dont know about these tiny cells - um i did the separate charger mod - with 4 aa's i charge for 2 min and get like 7-9+ min with 3.8, high speed gear (yeah i timed, this is full speed as much as possible, with lots of turns, i stop the timer when it slows during turns, still works for another 4-5+ min) also when i charged for 2 1/2 min the bottom of the car was warm - this is bad right? i should stick with 2 min? makes sense to me
Old 10-28-2002, 12:47 AM
Bunta Bunta is offline
Hi PhillyB!
I think your battery is good too.
I charge my 2 cell with 3.6 volts for about 3-4 minutes, sometimes longer but like you said the bottom gets warm.
-Bunta out
Custom Mods R us
Old 10-28-2002, 02:09 AM
NorCalCoug's Avatar
NorCalCoug NorCalCoug is offline
l33t camber wizard :)
If one of your batteries was bad your circuit would not have continuity and the car would not work. Also you should try the 3.8 on 6 volts of juice. With the transfer gear off it sounds like a dentist drill at high speed
Old 10-28-2002, 02:45 AM
JojoPB
wat is this i hear? u can fit a second bat over the PCB with the toyota bb body?? if so dat would be sweet... i just orderd one from HLJ
Old 10-29-2002, 01:01 AM
delmonk delmonk is offline
U can actually fit 2 extra batteries in the bb body, but u have to remove the PCB cover or else they won't fit. So its possible to do 3-4 battery mod with dremeling.
I prefer using the 2.2 engine over the 3.8 engine in my dual battery bb because the 2.2 engine has crazy torque. It flies over carpets, and with the grey "dirt" tires from the tire set it is my rally car heheh.
(Racing) Silver Supra with 2.6 engine, (Racing) Yellow FD3S witn 2.6 engine, Red Evo VII with ultimate light kit, (Drag) Blue R34 with 3.8 engine, (Rally) Twin turbo Yellow Toyota bB
Old 10-29-2002, 01:03 PM
well i was tryin to make the fastest car possible when i started, so using the fastest only made sense - i now run a 1.0 and its wicked fast no matter what gearin i use - btw i strapped a few pennies to the back of my dB body and any gearing i get wheelies but with the lower power gearing (blue i think) i get like wiked wheelies - if i hit reverse and get some speed then hit forward it launches a huge wheelie and if i hold forward it does donuts while doing a huge wheelie - and i can hold it like that in place for a long time till the batteries wear down - i cant wait to get a 1.6 motor - qfm was sold out when i ordered and refunded my money (wish they had kept my money and just sent it when it came in but oh well) - also i did all those drillings and lost a gram but get this - when i put the pennies on another body (pennies lower in the body for a lower cg) it handles great (kills runtime though) with alot of speed - as if it needs to be heavier to stick
The Layman's Dual Cell Mod (tm) actofgod Bit Science 207 02-16-2004 04:30 AM
which dual cell should i do, laymans, external, internal etc eman1 Bit Char-G / MicroSizers 11 09-02-2003 08:42 PM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 10:57 AM
and they said it couldn't be done! dual cell mod tory_103 Bit Char-G Mods and Projects 5 01-01-2003 08:03 PM
Dual cell mod and discharge problem (cell reversal). kenny_dilger Bit Char-G / MicroSizers 1 12-17-2002 11:23 PM
