07-01-2006, 12:24 PM
Naruto Champion
Slammed Wheels
can you put the slammed wheels from the truck on the mustang?
People come and go, but no one stops and looks.
Black/Red F150- Lift kit, body lift.
Black Camaro- 6th cell dragster with custom tires.
Blue Mustang-Slammed wheels
Black Hummer- Everything
07-01-2006, 01:56 PM
all the wheels go on the same way, so I don't see why not. Trick will be getting the body to fit right. Try it out and see.
07-05-2006, 10:05 AM
Naruto Champion
i did and it worked
07-13-2006, 12:33 PM
I tried that with a G35 and it still didn't fit. Even after cutting some plastic out of the fenders, but it turned out that I needed to widebody the sucker, and I have NO experience with putty work...But hey, if you found another way to pull it off, let me know. Thanks.
Where did the time go?
07-13-2006, 03:32 PM
Naruto Champion
i used it on the mustang. i used the UP suspension and had springs.
07-13-2006, 04:17 PM
This I gotta see... Can you post pics or something?
07-13-2006, 04:44 PM
Naruto Champion
here...
07-13-2006, 04:50 PM
Ah, so it barely fits. At least it works, right? Since I couldn't fit mine onto my G35 in the end (due to a crappy buget), I gave my wheels to someone else, but maybe I should see if I could get them back if he's not using them... Put them on Project: Supah Seven, perhaps...
07-13-2006, 05:17 PM
you should sand out the wheel wells and lower it back down. then u'll have ultamite handling, and it will look sick.
07-13-2006, 05:49 PM
Naruto Champion
it is so close to the sides but all the wheels turn
07-13-2006, 10:33 PM
Plus you're gaining ground clearance and higher top speed!
I'd do this if those wheels didn't cost so darn much.
