Old 06-28-2006, 01:12 PM
frizzen frizzen is offline
Tool User
Expanded Wheel Options
Did you know it's possible to make ANY set of ZZ/ZZ-SE hubcaps work with your monster truck rims?
I'm not gonna have the *real* tutorial up for a while, but here's the starting point. Pics later.
27/64" drill.
1/4" drill. (roughly)
flat file / sandpaper / knife / something to gnaw off plastic
4 ZZ-M rims
4 ZZ hubcaps
Some free time
Warning, this does make it impossible to stick the new hubcap pucks back onto a ZZ. This is one method of doing this, there are other methods you could use, I won't explain those. Do at own risk, don't blame me. If you screw up your parts, hope you learn from it. Don't attempt if you shouldn't be trusted with tools.
1. Use big drill on all 4 rims.
2. Use (file/sandpaper/knife/gnawing animal) to remove the index tab and the 3 pins off each of 4 hubcaps.
3. Use 1/4" drill to countersink (not through-hole) the back (inboard side, where the 3 pins used to live) of the hubcaps until they clear the lugnuts well enough the hubcap sits flush in rim. Do one at a time.
4. Hubcaps should simply press fit into rims.
5. To remove, push gently on one side of hubcap, it should rotate the opposite side up, gently pry raised side with something pointy.
Old 06-29-2006, 06:07 PM
Michael.mt2k's Avatar
Michael.mt2k Michael.mt2k is offline
Another old modder.
That is really nice.
I have to go dig mine out now and see what works with what.
Old 07-07-2006, 11:16 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Simple, elegant, and neat. Well done.
Wheel Weights! Steve ZipZaps Monster Truck 54 05-24-2006 12:40 AM
Xmods _FRONT_ Wheel Drive Daedalusleto XMODS Mods and Projects 7 05-16-2004 09:29 AM
just lost a wheel and two NEW metal wheel nuts... impression_xmod XMODS 1 04-22-2004 05:54 AM
Non front wheel turning or front wheel turning? bvsciguy Digi Q 0 09-13-2003 10:05 AM
