05-10-2006, 05:41 PM
Naruto Champion
6th cell
can i attach a 6th cell on the truck straight were the batteries meet the board.
People come and go, but no one stops and looks.
Black/Red F150- Lift kit, body lift.
Black Camaro- 6th cell dragster with custom tires.
Blue Mustang-Slammed wheels
Black Hummer- Everything
06-13-2006, 10:39 AM
Where does it go.
I also need to know where it goes on bothe gen1 and evo cars?
Please help.
06-13-2006, 08:30 PM
When you want to increase your voltage, you have to break the existing loop and series connect new batteries.
For the Evo's, I unsolder the red wire on the pcb and solder that to the negative of a battery holder. Then, I solder the positive of the battery holder to where the previous red wire was attached to the pcb.
On the gen 1, I cut the wire that goes between the two battery holders and add one in there. Again, the batteries need to be wired positive to negative all the way through.
07-01-2006, 12:40 PM
(insert something funny)
for gen 1 is it ABSOLUTELY nessecary (yea ha ha i made a spelling mistake) to solder the wires i did it to my evo by cutting wires so for a gen 1 why cant i just cut the wire use tape and wrap it up (thats a pun remember safe sex kids)
07-01-2006, 01:47 PM
In that situation you can. I still recomend solder because then you know the joint isn't coming apart and you have a better connection. When i'm testing things I twist wires together all the time. But when I'm finally done, I go back through and solder them.
07-07-2006, 02:37 PM
okay im going to get a honda civic body does any one know if 6 cells will sit cosy in it
07-07-2006, 04:41 PM
2 cells sit nicely on top of chasis under the body. That's what i formerly used on my blue civic.
07-10-2006, 11:03 PM
okay could someone explain to me the whole thing about the extra battery holders touching the antenna and short circuiting and if someone could give me a tip to prevent that it would be appreciated
also if i add 6 cells its fine right or will my xmod blow
