Old 03-21-2006, 10:50 PM
Slim
Solid axle
Hey guys i'm new here and i am going to get one of my friends Generation 1 Xmod for $2.00.
Has anyone ever atempted to take the axle parts and put them like in a tube so it will be solid..
Kinda like Killer's mini-z crawler?
Notes:
1. It's a generation 1 xmod
2. I will not be planning to buy a generatio 2 xmod
3. I will not buy anything online but only offline
4. this will probaly be a Radio Shack and Hobby Town USA project
Old 03-23-2006, 05:50 AM
color0's Avatar
color0 color0 is offline
Send a message via AIM to color0
basically, lock the diff? sure... take a sheet of binder paper, cut two circles the size of the large blue gear inside the diff, insert paper pieces into diff and re-assemble. yes, the diff pin should go straight through those pieces of paper.
simple, and temporary if you find you don't like the locked diff feel.
or do you actually want a whole, sprung, solid axle like a muscle car? for that, you might as well adapt the rear pod of a mini-z to your xmod.
Brian Ma
Greyscale Racing
Old 03-23-2006, 09:20 PM
Slim
umm i locked the axles already
i mean somthing like a TLT-1 Axle
Repairing a worn rear axle retaining slot rfnagel ZipZaps 5 01-22-2004 02:37 PM
Rear Axle Tip nrmcj Bit Char-G / MicroSizers 8 05-18-2003 02:47 PM
new and improved axle holder fix hogjowlz Bit Char-G / MicroSizers 1 03-04-2003 04:24 PM
heres a simple solution incase your rear axle doesn't snap into the mounting points spikeymike218 Bit Char-G Mods and Projects 18 02-16-2003 10:24 PM
