Old 03-21-2006, 04:24 PM
flamehead_16's Avatar
flamehead_16 flamehead_16 is offline
Naruto Champion
Paint
when i put primer on the car should i bake it with a heat lampp or just paint and sand
People come and go, but no one stops and looks.
Black/Red F150- Lift kit, body lift.
Black Camaro- 6th cell dragster with custom tires.
Blue Mustang-Slammed wheels
Black Hummer- Everything
Old 03-22-2006, 08:27 PM
HammerZ's Avatar
HammerZ HammerZ is offline
Thrasher
If you use anything more than a hairdrier, you run a good chance of deforming the body. Even a heat lamp can be enough to deform it. I have used hairdriers to dry coats of paint on lexan bodies with no problems. You do not want to hold it in one spot too long.
Old 06-24-2006, 10:33 AM
frog frog is offline
As far as painting, you really dont need to use primer on it unless you have done some fiberglass work to any of the parts. 1st I use a red scuff pad on the whole body to get rid of any shiney on it. Then I use dupont sealer, and the follow with the base color and then clear. Ive never had any problems. Even crashes and the stuff holds up pretty well. I just did another 03 cobra body, but I made a big cowl hood for it. I have yet to paint the hood on it. Here are some pics of the black one I did and then the yellow one with the unpainted hood. When I did the black car I baked it(after the clear) in the paint booth for like 6 min @110, but I was scared it would get deformed. On the yellow on I just used some PPG fast clear(air dries in 7 min) I wouldnt use anything to bake them though, too risky.
I will be painting the hood at work on monday. I was going to use the 04 cobra Mystic color, but I wanted the car to be bright to see it at night.(which is usually when we run them)
Paint in a Can! ~S20o0~ XMODS Parts and Hop-Ups 10 01-31-2005 02:03 PM
What do i need to paint my Xmod ron6 XMODS 11 10-27-2003 10:39 PM
How to Paint Lexan Bodys headhunter555 ZipZaps 14 02-26-2003 04:35 PM
Paint Jobs For Sale/trade! Superimport2nr For Sale/Trade 12 01-25-2003 09:31 PM
