Old 03-11-2006, 05:20 AM
fisherman2000 fisherman2000 is offline
Question charge rate??????????
can a gp120mah three cell pack stand a one amp charge rate?I have a peak charger but it only has one and four amp rate.
I have a 300mah wall charger I use now.I charge my tri cell for about 25min.s is that too long?
I have been using a 4.6V .9amp flashlight bulb as a dis-charger on each cell becouse one and two cell hold a longer charge then the third.The more I do this becouse then each cells has the same charge. basiclly there gas tanks and if ones allready full and you try filling all three the fuel starts to vent and blows out the tank.
Penny for your thoughts
Old 03-14-2006, 11:27 PM
pspjunkie pspjunkie is offline
Send a message via AIM to pspjunkie Send a message via Yahoo to pspjunkie
no, because the maximum for 300 mAh is .4 amps, so you would definately do quite a bit of damage to your battery by charging it at 1 amp.
At least Im 95% sure, unless someone can prove otherwise, but im pretty sure that the battery couldnt handle it.
The Layman's Dual Cell Mod (tm) actofgod Bit Science 207 02-16-2004 04:30 AM
The Truly Versatile Charger Project (tm) actofgod Bit Science 18 05-20-2003 07:59 AM
Holy Sheet Scar Dynamite Rocket Racer 28 01-17-2003 05:56 AM
My LXX won't charge Nenox Bit Char-G / MicroSizers 3 11-30-2002 07:16 PM
