03-08-2006, 10:55 AM
Steering/New Servo Questions
Hey...New to the xmod and I got a couple of questions:
1) Can you replace the stock servo for something a little more "race/hobby" quality?? Some like a hitech Hs55 or in that area
2) on the back of the stock servo, there is a blue and red wire that appears to attach to the area near the FET...what does this wire do??
thanks
I like you. You remind me of when I was young and stupid
PottBelly's R/C Raceway | Team Tekin | GQ Tires - Competition R/C | MaxAmps com | Motek Racing | Team Belly
03-09-2006, 07:32 PM
To awnser your question, Not really, but you are able to get upgraded servo's in the Suspention & Steering Kit.
2 ZZ's 1 ZZMT, 6 Xmods
03-10-2006, 01:57 AM
From what I've seen, that kit has NOTHING to do with the servo, just the springs and toe-in...
Was looking to replace/upgrade the existing servo - and I'm faily certain that kit won't do what I need...It will help with the handling, but not the servo
thanks anyways
03-10-2006, 05:48 PM
Oh yeah, that was the tie rod... Sorry man.
03-11-2006, 03:19 AM
you can bypass the servo board in an HS-55 or similar hobby servo, and then route the proper wires from the xmod pcb to the servo pot and motor;
but if you're going to do that you might as well use another pcb, something better like iwaver or kyosho.
03-11-2006, 06:35 PM
thanks...but do you know what the blue and red wires are coming off the stock servo??
03-12-2006, 06:44 PM
that's for the xmods' servo motor.
03-13-2006, 11:07 AM
then what do the 3 wires in the plug do?
They look like the "standard" postive-negative-control set-up of a normal servo...
