Old 02-19-2006, 02:19 PM
joez2872 joez2872 is offline
zzmt idler
i did the idler gear mod wow what a difference crawls over anything ,,? tho mess is kinda tight would graphite help ? thanks
Old 02-19-2006, 02:21 PM
hers the all the gang with there rides and long live #3
Old 02-19-2006, 02:38 PM
Michael.mt2k's Avatar
Michael.mt2k Michael.mt2k is offline
Another old modder.
Re: zzmt idler
When I performed the 4-gear mod, I used a pin-vise drill stuck through the idler gear to get a feel for how everything would move as I tried different spots.
When I found a location that worked I dug in the drill to mark the spot, removed the gear and finished the job.
Is it tight when you don't have a motor on it and you turn the wheels?
I've mis-spaced motors before and it ran tight.
Graphite is the only thing I would use, and might help.
Nice pic! I like the Rottie.
Old 02-19-2006, 06:55 PM
it moves free with ou the motor alittle tight but not that bad as with motor , i guess ill have to space it up more thanks guys ,now its time for the 3 cell
Old 02-19-2006, 07:20 PM
chilli_mp138 chilli_mp138 is offline
perpetual newbie
joez2872--
Good work. You can see my tutorial on the mod and other gear arrangements on my website.
chilli
www.gcrossett.com/zipzaps/
Old 02-19-2006, 11:11 PM
i got to say battery life has went down unless my gear mesh is til to tight ,anyadvice ?????? thanks guys
Old 02-20-2006, 08:00 AM
Another old modder.
What's happening with this mod is that the motor has to turn more times to turn the drive wheels, resulting in more power on the ground.
These MTs are obviously engineered out of the box for a balance of performance and running time based on the materials used.
Any changes that fall outside the known ones are going to have an effect somewhere.
I added another parallel-wired battery pack from a scrapped MT for more running time.
Old 02-20-2006, 01:40 PM
Jazz32
interestingly enough, mine has much longer runtimes. I'm not using a zzmt motor though, I use a motor out of a clone that is slightly bigger and has lots of torque.
Motors will draw the most current when under heavy load. It's true the motor has to turn more to move the truck, but in either gear setup, the motor would reach its peak rpm. In the 4 gear case, at peak rpm, the load would be less. If you're really working the load to crawl over things, then the battery life will go down.
Old 02-21-2006, 05:53 AM
Another old modder.
Using a different motor will indeed change things, but at that point you can no longer draw a comparison in the same manner that we are.
The amount of load will always reduce the battery time no matter what the gearing is.
With the four-gear mod, the motor has to spin more times to move the truck the same distance, thus it's running for a longer time regardless of the amount of load.
The tradeoff is that the load on the motor is reduced but it has to spin more to get the job done.
The classic engineering trade-offs.
You simply don't get something for nothing.
Old 03-06-2006, 08:27 PM
Lord_HelmetR34's Avatar
Lord_HelmetR34 Lord_HelmetR34 is offline
Bit Crazy
For mine, i used small strips of ZZ packaging to raise the motor up enough so that the gears don't bind. It works pretty well........
Dubshop Customs
Old 04-08-2006, 07:37 PM
krueskrewer krueskrewer is offline
Send a message via AIM to krueskrewer
hey lord helmet. did you ever try to fit a dime or penny in those wheels when spun around like that?
fit almost perfect it's funny as hell
SS + ZZMT = SZMT, My SuperZip MT Jazz32 SuperSlicks Gallery 3 08-22-2007 09:40 AM
My Z can use the ZZMT controller 'Vette Nerd Atomic Z-Cars 8 06-01-2006 12:16 PM
ZZMT Stuttering zzultimate ZipZaps Monster Truck 6 04-18-2006 10:33 AM
ZZMT, Xmods, ZZ;s... ZipZapin For Sale/Trade 3 05-12-2005 01:38 PM
