Old 10-19-2002, 11:18 PM
joeNuggetz joeNuggetz is offline
Just noticed something interest
I thought my rear axle well was beomming loose on one side. I've read posts about people inserting foil or something in there to tighten it up. I just finished my dual cell mod and was thinking "damn, it sucks that I finally get my cell mod to work and now a problem comes up.
Anyway, if I try a different axle, if fits fine. Moral of the story? If you think you've stripped your rear axle well, try a different axle. If might fit better.
Thats all
Old 10-19-2002, 11:52 PM
Kajoq's Avatar
Kajoq Kajoq is offline
4r3 j00 ub3r l337 h4xx0r?
Send a message via AIM to Kajoq
Ive got one of the cars that requires foil wrapping, and its not the axle... its the chassis itself that has been worked wider and wider from me changing gears to often
Shiggity Shiggity Shwa.
Old 10-20-2002, 12:00 AM
Kajog, by the way, the foil from inside of a pack of smokes does works great!!
I LIVE TO ZIP
Old 10-20-2002, 12:39 AM
marc515192's Avatar
marc515192 marc515192 is offline
ZipZap Maniac
Send a message via Yahoo to marc515192
Thumbs up I got it
Was gonna post this earlier but I had the same problem.
So I put a drop of CA glue (krazy glue) on the loose side and voila! Just like knew. I think the CA gel type glue will work better because you can control the shape.
My $.02 worth.
1999 Super Modified Zinc Yellow SVT Mustang ZZ
Bit PCB MOD
It's a sleeper! hehehehe
M/S Mitsubishi EVO Lancer w/modified clone motor
M/S Nissan Skyline
M/S Honda S2000
Old 10-20-2002, 12:43 AM
How do you shape the glue. Can you please explain with a little more detail? I'd like to know I have a different option in case this really becomes a problem for me. Maybe I will assume that you put some glue in the problem spot, let it sit for a bit and the stick an axle in the there and roll it around. Then take the axle that you just used and throw it in the garbage since I assume its trashed. Once everything's dry, yer good to go? Is that what you did? If so, I saved you some typing, is not, I just type this for nothing
Old 10-20-2002, 12:50 AM
marc515192's Avatar
ZipZap Maniac
With the Gel type you just need a small little drop (shape I mean doesnt run so the drop stays in one place)
First fit is snug but it works great!
Bit PCB MOD
M/S Nissan Skyline
M/S Honda S2000
Old 10-20-2002, 01:04 AM
go_zz_go's Avatar
go_zz_go go_zz_go is offline
more power!!
i think i understand leave the axle out and just put a little dab on the loose side where the axle goes in let it dry and there it should be tighter fit am i close?
Old 10-20-2002, 01:08 AM
marc515192's Avatar
ZipZap Maniac
Right on the money!
Bit PCB MOD
M/S Nissan Skyline
M/S Honda S2000
Old 10-20-2002, 02:27 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
that sounds like a more permanent fix. im sick of messing around with foil. btw i got the k.i.t. racer and the white slicks are great. much tighter turning.
Old 10-20-2002, 08:44 PM
catman25 catman25 is offline
i used my hot soldier irona nd had it cool for about 4min ..just another to melt the plastic enought ot shape it ..i melt just below the snap part of the chassis and it pushed the plastic almost up the hole and it was hard to snap in the first time now its like brand new.i thought crazy glue makes plastic brittle??if you use my method make the iron just a lil hot and dont use excessive force..you dont weanna ruin the shpe of the body just put plastic where it belongs peace-cat-
What I noticed about RS!!! XMODSaretheBEST XMODS 22 12-02-2003 09:19 PM
Noticed something else in the jeep zipzap! ZipZapper1 ZipZaps 1 11-02-2003 03:33 PM
Noticed something viperkilla XMODS 4 10-21-2003 06:38 PM
has anyone noticed this? isk8blind Bit Char-G / MicroSizers 3 02-12-2003 07:57 PM
noticed something interesting while switching pcb boards spikeymike218 Bit Char-G / MicroSizers 7 01-22-2003 02:03 AM
