02-08-2006, 09:31 PM
wallcharger
can i set my wall charger two 6 volts and charger my zz mt and for how lomg thanks, radio shack charger thing adjustable 3-12 volts 800 mhttp://www.radioshack.com/product/index.jsp?productId=2049691&cp=2032056.2032136.203 2153&pg=4&parentPage=family
02-12-2006, 09:59 PM
wow no one can help me out here ??????????????????
02-13-2006, 12:18 AM
The truck runs on 2.4V and charges with 4 batteries at 4.8 volts. I would highly recomend you not set it to 6 volts but rather 4.5. I don't know how long it would take to charge, probably a minute. When you ask for help too, try to write correct complete sentences.
02-13-2006, 07:09 AM
Another old modder.
When making technical requests, it's always best to be as precise as possible with your wording.
Take a couple of minutes and read over what you've written before posting it, or edit it afterward. (before is always best)
The wrong word (two, as opposed to too) can change the meaning quite a bit when you are discussing technical stuff.
While we're all MT fans here, the stuff we're discussing is largely technical.
If someone doesn't understand your question it's very likely it will just get ignored!!
_I_think_ you are asking if you can power your MT controller from an AC adapter.
If so, then the answer is yes, _if_ it is set to 6 volts and _if_ it's connected correctly.
I am not going to go into step-by-step instructions on how to do it, but it can be done.
If you are just getting started modifying this stuff it is a very good idea to check out some basic electronics tutorials before getting started.
Also, make use of the search function.
Good luck with your project!
