Old 10-19-2002, 07:21 PM
BLWNSTNG BLWNSTNG is offline
The online drunk
100mah + 150mah dual batteries?
I am going to order another battery for my ZZ. I might do the dual battery mod and was wondering if I can use the 150mah with the stock 100mah. The main reason I'm ordering the battery is that I did the no/rev mod and it doesn't run as long but is faster . I'm also going to order the 3.0 motor(maybe the 3.8, not decided yet). Thanks for any help, Mike.
Old 10-19-2002, 07:44 PM
marc515192's Avatar
marc515192 marc515192 is offline
ZipZap Maniac
Send a message via Yahoo to marc515192
The battries should be the same.
1999 Super Modified Zinc Yellow SVT Mustang ZZ
Bit PCB MOD
It's a sleeper! hehehehe
M/S Mitsubishi EVO Lancer w/modified clone motor
M/S Nissan Skyline
M/S Honda S2000
Old 10-19-2002, 11:49 PM
The online drunk
I read somewhere that you can run a 100mah with a 120(or 135)mah and be ok. The main thing was that they were both the same voltage and the same style battery(NiMH).
Old 10-20-2002, 01:43 PM
Axel's Avatar
Axel Axel is offline
Send a message via Yahoo to Axel
Ya, that will work fine for you. Just make sure they're the same voltage.
-Axel
+Red RX7 ZipZap
-Dual-cell mod (2.4v)
-Antenna mod (100+ feet outside!)
-green ground effect LED ligthts mod
Old 10-20-2002, 02:17 PM
The online drunk
Axel. You wrote in another thread regarding jumping the two resistors. You said not to do the dual battery mod(in series)because it could fry something. I cut the yellow wire and ran it straight to the pos side of the battery to increase voltage. Can I do the dual bat mod with this settup? Thanks for any help, Mike.
Dual batteries now Zero power shocon2k Bit Char-G / MicroSizers 1 12-17-2002 11:27 PM
150maH batteries actofgod Bit Char-G Mods and Projects 17 11-17-2002 09:46 PM
Dual Batt. Mod stevensmd3 ZipZaps 13 11-16-2002 03:03 PM
My ZipZap now runs circles around my Bit! (dual batt success) caver01 ZipZaps 16 11-05-2002 11:22 AM
Where can I buy 1.2v 100mah batteries? Undead98 ZipZaps 6 10-07-2002 02:27 PM
