Old 01-03-2006, 10:31 PM
Cyfiawnder Cyfiawnder is offline
In line Stearing Mod??
Can anyone give me a link (that works) for the HOW to on doing the Inline Resistor Stearing mod. I've found a scant few on the WEB and they all lead to broken links. The only thread I found on here was a "I need help with inline stearing mod" It was just a cry for help from someone who did the mod but was having problems. All I can find is you need 3.3 or 4.7 k-ohm resistors. 1/4 Watt works, but 1/8 watt is better... and so on. I have not been able to find Which wires the resistors go on.
Loud doesn't = fast.
Import doesn't = quality.
Chrome Doesn't = performance gains
Clear Tailights just make you easier to spot.
My 4 cylinder has 210 Natural aspirated HP is only 2.3 li, and is 15 years old, and it was built right here in the good ol' USA.
Old 01-04-2006, 07:44 PM
Thumbs up
Well after some more searching, and piecing together tidbits of information, I figured it out on my own... thanx for the help It works flawlessly. I used te 3.3kohm in line resistors (the 1/4 watt-5% tolerance ones from ratshack). The wheels turn lock to lock, but the tires DO NOT rub on the stops that stick out behind the wheels. I'd say it turns at least 35% tighter than before. Now I can do doughnuts without the drift wheels Yeah! Those are going back to radio shack
It took me some time because I didn't have any directions. I also manually centered the horn too so now it (almost) drives in a straight line without having to use the trim buttons!! Oh and for all of you's out there that are complaing about steering slop at the knuckles I got two words for ya Teflon Tape. No binding like silicon hose jamed on there and it uber cheep.
Best Mod Contest (UNOFFICIAL) midget_man1387 Bit Char-G Mods and Projects 56 03-17-2003 10:38 PM
