Old 01-02-2006, 04:44 PM
yellow15092 yellow15092 is offline
Angry lift kit for XMOD Truck
I just recently purchased the offroad upgrade kit and when i put it together my motor was stripping out. I took it all off and tried it again, it was still stripping out. I changed the pinions and everything, it still did not work. When i took it off, my truck worked fine.
Does any one know why this is happening? Thank you
______________________________
Orange F-150
all mods from RS
Old 01-02-2006, 07:56 PM
choptop choptop is offline
superzap
yes this happened to everyone i know who has a lift kit. it is actually the dogbone. the angle is too extreme and it pops out of the cup. i have also had problems with the awd kit in both the car and truck.
Old 01-03-2006, 09:37 AM
Boost Freak Boost Freak is offline
This is also happening to my brothers truck, It grinds and makes alot of noises.
Old 01-03-2006, 10:28 AM
superzap
once you yake out the lift kit , it works normal.thats 6 people i know of who have had problems with it.
Old 01-03-2006, 08:28 PM
flamehead_16's Avatar
flamehead_16 flamehead_16 is offline
Naruto Champion
i had the sam problem as well
People come and go, but no one stops and looks.
Black/Red F150- Lift kit, body lift.
Black Camaro- 6th cell dragster with custom tires.
Blue Mustang-Slammed wheels
Black Hummer- Everything
Old 01-03-2006, 10:00 PM
superzap
we all should write radio shack to complain about this crap
Old 01-03-2006, 11:06 PM
Easymoney Easymoney is offline
I never had this problem with my truck. Are you sure you have the right shaft in the right place? The front shafts are different then the rear. The front shafts have a ball end on one end and a flat on the other end. Check your instructions and you will see what I'm talking about. I noticed this before I had my truck completely together so that could be why I never had the problem. Hopw this helps ya. Later
1999 Red & Silver Nissan Skyline R34:
AWD, All RS Hop Ups, Tiny R/C Bearings, GPM rear outdrives and axle shafts
1999 Black Nissan Skyline R34:
AWD, All RS Hop Ups, Tiny RC bearings
1965 Blue Ford Mustang:
RWD, All RS Hop Ups
2004 Blue Subaru Impreza WRX STi:
AWD, All RS Hop Ups
2005 Blue Ford F-150:
Lifted 4x4, All RS Hop Ups
Old 01-04-2006, 09:13 PM
superzap
i never noticed that, i will check it out thanks
Old 01-06-2006, 03:50 AM
Also I forgot to mention that the rounded end on the front shafts goes in the outdrive side not the differential side. The reason for the ball end is so it can turn and not pop out and not bind up. Hope this helps someone fix their problem. Later
Easymoney
RWD, All RS Hop Ups
AWD, All RS Hop Ups
Old 01-07-2006, 02:21 PM
thanks for the info....ill try it out
Orange F-150
all mods from RS
Old 01-09-2006, 01:56 AM
newportconv
i had a similar problem with mine binding but found that i out the wrong screws in the front end. the ones with the long smoth shaft insted of the short one and my truck runs great nowadays
Old 03-01-2006, 12:24 PM
baleisen baleisen is offline
Micro R/C'er in Da Burgh
Send a message via AIM to baleisen
I am using rear dog bones in both my truck and my car. Both are normal height and AWD. Car bones for the car, truck bones for the truck. Universal rear axles for front and back on both also.
BAE
Smaller models, more control
Old 03-30-2006, 05:24 PM
somebody5788 somebody5788 is offline
i have yet to have a dogbone problem and i do plenty of driving. I do wonder if it has anything to do with the flat on one side of the dogbone.
Old 03-31-2006, 12:39 AM
I am running all aluminum parts in my H2. They are not plastic dog bones. My F150 truck is lifted and 4WD. The bones (plastic) never pop out of it either, but it only has RS parts, no aluminum, so it isn't that fast.
BAE
Old 04-24-2006, 12:43 PM
Sinni Sinni is offline
did u do the metal berring upgrade? if so, u left the upper torque converter berrings as plastic? I've had numerous trucks come in cause of "Grinding", and they put the small metal berrings on the upper torque converter. Those berrings are for the AWD and no the upper torque converter. Also i've had a couple that when they put in the s2 motor, when they pulled the torque pinion they accidently pulled the pin with it and didn't put it or the new one back in.
if the dogbones are "falling out" of the cup, and u installed the "Off-road kit" u put the front dogbones on the back. It should b the dogbones that are flat on both ends.
CJ's Xmods FAQ (Updated June 27th.) cj1267 XMODS 64 05-30-2007 08:43 PM
BOO on lift kit....maybe krueskrewer XMODS Parts and Hop-Ups 7 06-10-2006 12:39 AM
truck lift kit help!!! grnjetta6 XMODS Parts and Hop-Ups 1 01-30-2006 12:57 PM
EVO Lift kit Bump Steer offroader_10 XMODS 6 11-02-2005 09:18 PM
My Xmod Lift Kit microINNOVATION XMODS Parts and Hop-Ups 37 01-24-2005 03:51 PM
